Limited slip?
Old Feb 8, 2011 | 10:13 AM
Hunt89's Avatar
Hunt89
Limited slip?
<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> <table border="0" width="100%"> <tbody><tr> <td valign="top" width="100%"> I have a 89 f150 300 i6 4x4 with 3.55s. I switched from 3.08s to 3.55s. I wanted to say that the 3.08s were limited slip. My 3.55s are not. How much trouble would it be to make them limited slip? </td></tr></tbody></table>
Old Feb 8, 2011 | 10:31 AM
92nite351's Avatar
92nite351
use the limited slip assembly from old setup and install 3.55 ring and pinion..r u sure the 3.08 was a limited?
Old Feb 8, 2011 | 10:32 AM
dclack's Avatar
dclack
The gear ratio has nothing to do with whether it's an LSD or not. It's the carrier that determines LSD. How did you change you gear ratio, did you have a shop do it or did you just swap the whole axle?
Old Feb 8, 2011 | 10:39 AM
Hunt89's Avatar
Hunt89
I think but I'm not really sure. I could be wrong
Old Feb 8, 2011 | 10:43 AM
Hunt89's Avatar
Hunt89
I swap the whole axle. I got it from an 89 bronco.
Old Feb 8, 2011 | 11:00 AM
92nite351's Avatar
92nite351
so u swapped the whole housing, didnt take the axels and guts out of the old one and put axles and guts from new one into old one?
Old Feb 8, 2011 | 11:05 AM
dclack's Avatar
dclack
Then if you still have the old axle and it is limited slip, you can swap the carrier into your new axle. You'll have to check the backlash and mesh pattern, which you can learn how to do by searching the internet and youtube.
Old Feb 8, 2011 | 04:37 PM
USMC0351fordtruckin's Avatar
USMC0351fordtruckin
i wouldn't go swappin old **** in tryin 2 build a LS from 2 use rears go find a truck in the junkyard with 3.55LS and put the whole thing in or get 1 built that runs around $500 either way its gonna cost u money.... if u pc them together it will cause u a lot of trouble and u will have 2 pretty much rebuild them anyhow.... im not positive but i dont think that 3.08 rear had LS i think they were all open diffs??? if anyone knows 4 sure tell me....
Old Feb 8, 2011 | 06:11 PM
jas88's Avatar
jas88
LS was not available with the 3.08 gear AFAIK.
Old Feb 8, 2011 | 08:46 PM
redlightning93's Avatar
redlightning93
Correct answer!
Old Feb 8, 2011 | 10:29 PM
rla2005's Avatar
rla2005
According to this chart: Ford Axle Code Chart .: Articles
Axle Code H8 is a 3.08 limited slip rear axle. The weight rating also matches the Code 18 listing so I would assume both are Ford 8.8" rear axles. Whether or not that applies to earlier or later models is another question?
Old Feb 9, 2011 | 02:59 AM
TexasGuy001's Avatar
TexasGuy001
I have never seen 3.08 LS either.
Old Feb 9, 2011 | 03:55 AM
jejdavis's Avatar
jejdavis
If you still have the old diff look at the tag, if LS it will say 08L in the last digits, if not it will say 308, as long as you do the back lash right and the gears don't look chewed up or anything I wouldn't worry about it, in my 8.8 before 9in swap I put in a carrier from a bronco and never had a problem, I am surprised that the bronco didn't have LS
Old Feb 9, 2011 | 04:42 AM
lew52's Avatar
lew52
Not sure about the truck , but some of the mustangs came with 3.08 LS....Lew
Old Feb 9, 2011 | 08:43 AM
Hunt89's Avatar
Hunt89
Thanks everyone for all the info
adrianvip
6.7L Power Stroke Diesel
Mar 7, 2020 01:45 PM
speakerfritz
Jul 30, 2014 03:18 PM
vloney
Nov 2, 2013 09:56 PM
Bowie
Nov 6, 2008 03:05 PM
