starter relay wire
Old Mar 10, 2003 | 09:19 PM
torquemeister's Avatar
torquemeister
starter relay wire
I need to test my starter relay wire to see if it's the reason my truck won't start (by running another wire from the ignition switch to the starter solenoid). I guess it's time to buy a voltmeter! Does anybody know what guage it is?
Thanks,
TM
Old Mar 10, 2003 | 10:00 PM
steve83's Avatar
steve83
starter relay wire
Probably ~20ga, but all you have to do to test it is put a test light from the LB/R wire to the (-) battery terminal and turn the key to START. If the light comes on, the wire is good and sending power to the relay.
To test the relay, just jump from its terminal with the battery wire to the small one (AFTER making sure the truck is in Park or Neutral) - the starter should engage if the relay is good.
Mab1957
Oct 21, 2015 01:25 PM
1992FordF150Custom
13
Nov 6, 2013 06:54 PM
jmessin5
Dec 3, 2010 08:24 AM
LARIAT 85
May 25, 2007 10:49 AM
weldman
Electrical Systems/Wiring
Mar 18, 2001 06:17 PM
