Ft drive shaft came loose and mangled the floor
I have a 94 f250 super cab auto 4x4. Earlier this week the u-joint on the ft drive shaft at the t-case came loose and the loose drive shaft did some pretty amazing damage to my floor right next to the t-case shifter hole. What I am planning to do is cut out the damaged sheet metal and replace it with the same piece cut out of a 89 f350. I was wondering if the floor and trany tunnel on the 89 are the same as the 94, and if it matters that the 89 is a regular cab. Any and all help will be greatly appreciated.
goda123
11-30-2008 04:37 PM
Dustin_86
02-04-2004 08:36 AM
BigJake86
04-25-2003 12:23 PM
