Tire question
Old Feb 7, 2011 | 06:24 PM
anjcohen's Avatar
anjcohen
Tire question
If I want to put on LT285 75 16R's on a stock 350 Crew 7.3 do I have to level off the front for better tire clearance? Either way could I get by with a 1.5 inch using a leaf add on in the front?
I do not want to compromise anything. I had many issues in the past when I made the mistake of taking my son's advice and had my last truck lifted 6 inches! Want to keep it simple.
Thanks
Old Feb 7, 2011 | 06:28 PM
snakedoc's Avatar
snakedoc
i have that size and i have not had i rub.
Old Feb 7, 2011 | 06:31 PM
anjcohen's Avatar
anjcohen
So you put those tires on stock set up? No level off?
I had those Firestone Destination A/T's on my last truck and liked them much better than previous BFG's............
Got good ratings on the Tire Rack also.
Old Feb 7, 2011 | 07:15 PM
cps's Avatar
cps
I put that same size of tire on my truck but they would rub the mud flaps that i have when i would turn sharp. They would also rub if i went over a bump and was turning at the same time. I added another leaf in the front and it was all good. Looks better too and firmed up the front end to the point where i could maybe take the swaybar off. Roy.
Old Feb 7, 2011 | 07:32 PM
anjcohen's Avatar
anjcohen
So you just added one leaf to front? That was my plan as I did the same in 2000 on my 99' 7.3. I had no issues until I got a 6" lift! Never again. Staying close to stock as I can with limited modifications such as 4" exhaust, limited tuner more for fuel economy on freeway, new Ford ASI, level front as described, John Wood Valve body. Thats about all I will do......
Old Feb 7, 2011 | 07:48 PM
roostercrows's Avatar
roostercrows
You don't "need" a lift necessarily, the rubbing is very minimal, so the leveling kit is optional.
Lots of guys on here are running that size of tire, some with the kit some without.
Old Feb 7, 2011 | 07:51 PM
cps's Avatar
cps
Yep, thats all. Shock length was fine, as was everything else. It basicly leveled the front end.
Old Feb 7, 2011 | 07:53 PM
snakedoc's Avatar
snakedoc
no level stock rims. i had BFG's before the Firestone and these are much better ride and traction,
Old Feb 7, 2011 | 07:54 PM
7MAGMIKE's Avatar
7MAGMIKE
I run 285/75 R16 BFG A/T KO's on mine with no lift. No problem.
Old Feb 7, 2011 | 07:55 PM
anjcohen's Avatar
anjcohen
Sounds good. I just thought I could get new tires (Firestone Destination A/T's) LT 285 75 16R's and get the level off later.
I purchased this truck with some brand tires I never heard of OEM sizes - the tire brand is "BCT"
I dont screw around with tires and like quality rubber. Thanks
Old Feb 7, 2011 | 07:58 PM
anjcohen's Avatar
anjcohen
I agree with you regarding the Firestones vs. BFG's. Now the big question is do I put the white letters on the outside?....(<:
big poppa's Avatar
big poppa
285'S here also, you'll be fine.. Blackwalls out, I would anyway, your choice.
Old Feb 7, 2011 | 08:03 PM
anjcohen's Avatar
anjcohen
Excellent - good to know. I didn't want problems with no level kit as I need tires first. Thank you!
Old Feb 7, 2011 | 08:04 PM
anjcohen's Avatar
anjcohen
what kind of CB do you have? I see the image of your truck....
Old Feb 7, 2011 | 08:16 PM
snakedoc's Avatar
snakedoc
white goes out. my dad had his black out and they dont look as good as mine.
