I was up in the White Mountains of New Hampshire this past (cold) weekend doing some skiing at Cannon Mountain. I was sitting in my truck eating my breakfast because the lodge was mobbed with 7-14 year old ski racers, with my truck running for a little bit of heat. It was about 15 degrees out, and my truck would kick up to a high idle and the EBPV would kick on. I have a 3-1/2" downpipe with 4" straight exhaust after, so needless to say she sounds like a commercial leaf blower. With families walking past in the crowded parking lot, I felt a little bit bad for them so I'd just keep tapping the brake to bring her back down to low idle with the EBPV off (open?)
This got me thinking about the purpose of the EBPV in this situation. Is it to get the engine warmer, or is it bad to run at such low temps with the EBPV off for an extended period of time? I guess I just want to know what the computer is thinking under the hood, and why she does what she does...
I believe I've heard that extended idle time with a cold engine risks having the wet stacking. That's the unburnt fuel hanging up (stacking) on the valves that could lead to the piston striking the valves. That's why the idle is controlled by the engine oil temp among other things.
The purpose of the EBPV is to help warm the engine to normal operating temps. When it is at operatinng temps the truck will continue to engage the EBPV while idleing to prevent wet stacking. Wet stacking occursd when the engine idles to cool. It is when unburned fuel builds up in the valve and injectors
That's great info, thanks guys. What I ended up doing was just resting my boot on the pedal around 1100 RPM, which got me thinking...which will bring this thread on a totally different tangent...but is there a way to get the cruise control to work while in park? What I mean is, is there a way to set the cruise control to hold the engine at a specific RPM, or did I just post up a million dollar idea for somebody to steal?
No. Most of the tuners have a high idle position available just for that situation. I really like mine in the summer to spin the A/C comp when setting for a while. In the cold I just let the truck do it's thing, if it needs to idle up I just let it.
Yeah I've got a 6-pos DP that I need to fill 3 slots on...one is going to be high idle with EBPV off probably...i just figured an idle/cruise RPM holder would be a good idea for non-chipped trucks*.
*or people who dont want to use a tuner slot just for high idle
Reason: clarification
Technically, the term 'wet stacking' refers to 2 stroke diesels and the effects are much more severe - but the cause of the problem is similar - incomplete combustion. For us, this means coking in the combustion chamber and exhaust valves.
I would never idle at 600rpm for very long - especially if its COLD outside. Even using 1100rpm hi-idle, EOT and combustion chamber temps fall very low im the coldest weather. As far as EBPV, I'd like to activate it more often than PCM does... Imho, it is necessary for fast warm-up AND extended idling like you described.
If the noise is a problem, park further away!!
It's not really a problem, I just felt kind of bad for the little kiddies and mom's walking by...but my truck's health is on the line they can deal with it from now on. Thanks for all the info.
Ford offers an auxiliary idle control module for just such a situation.
