block heater draw?
Old Feb 7, 2011 | 09:28 AM
Rose Clifford's Avatar
Rose Clifford
block heater draw?
How much electricity does the block heater draw? 1400 Watts?
Old Feb 7, 2011 | 09:32 AM
goingincircles22's Avatar
goingincircles22
I think its 1000 watts. At least thats what mine was.
Old Feb 7, 2011 | 09:47 AM
Rose Clifford
thanks....
a couple weeks ago my room mate/landlord; "John, we need to talk about your block heater...the electric bill went up $90 last month."
LOL!
At least utilities are included in my rent...it's on a timer now to come on 3 hrs before I leave for work, and thats only during nights when its supposed to drop below 20F. I don't know what we get charged for a kWh but I'm guessing it should add up to about $25/mo if i use it 5 days/wk which I don't.
Thanks for the answer,
John
Old Feb 7, 2011 | 09:56 AM
Vinford's Avatar
Vinford
Someones bsing you if they say the bill went up $90.00 a month.
Old Feb 7, 2011 | 10:02 AM
goingincircles22
Well it is like leaving on 10 100w lightbulbs all night. Mine only got plugged in if the temp was going below 25 that night. Timer is a good thing but I would put a thermostat relay on it so it only comes on at your set temp.
Old Feb 7, 2011 | 10:28 AM
clintbonnie's Avatar
clintbonnie
If you not using a syn oil such as rotella 5w40 you probably need that engine heater.. But, if you switched, you don't need to plug it in... saving that $..(unless it below 0, then i would plug it in). The heater just thins the dino oil to what the syn oil is normally.
You will get faster cold starts and a quieter running engine.. and it better for your turbo too.
Old Feb 7, 2011 | 11:21 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
I switched and still need to plug it in. Went back to 15-40 yesterday after speaking to Termy Engineering about oil.
Block heater is 1000w, 8amps, 15.45ohms when good. Just replaced mine. If in dire need, it can be found at Carquest.
Old Feb 7, 2011 | 12:59 PM
Rose Clifford
I've thought about the syn oil, but dont feel the need to get it. It's a lot of money and dino seems to work just fine. My plug/timer for the block heater is right next to my front door of the condo, under the overhang so it's not a pain for me to look at the temp before I call it a night and decide whether or not to plug it in.
Old Feb 7, 2011 | 01:01 PM
Rose Clifford
i saw it, it went from $90 to $180. Not entirely because of the block heater, but some of it sure was
Old Feb 7, 2011 | 01:32 PM
ltl_jrw's Avatar
ltl_jrw
Some say that if pluged in for 24 hours it will use about $1.00 a day, just going by what others say????????????????????
Old Feb 7, 2011 | 01:41 PM
Mike F250's Avatar
Mike F250
Can you splain why you switched back?
I went with the rotella blend 10w40 based on a conversation with a member here that was a distributor. He told me to go with the blend because of summer heat and heavy towing.
Old Feb 7, 2011 | 01:44 PM
erichy's Avatar
erichy
Mine starts up no problem at 7 degrees after switching to Rotella T6 synthetic. I used to get the romps below 25 now it never has once. The extra 20 bucks for the oil negates the increase you'll pay in electric and the injectors love the stuff. Just my 2 cents for what it's worth.
Old Feb 7, 2011 | 03:03 PM
clintbonnie
The "40" is what the viscoity at operating tempature.. So there is not much difference between dino and syn if both have "40"... The "5" is the visocity at colder temperatures, (5 being thinner) which is which the syn oil really helps on starting in cold weather.. There is no reason you can't run syn 5w40 year round..
Old Feb 7, 2011 | 03:29 PM
twags6's Avatar
twags6
The cost to run it depends on what the electric co charges per kWh. Mine works out to around 14 cents per kWh, so running it 10 hours a day would be 1.40 or $42 a month. Some places charge more, so you you could easily spend over $50 a month running the block heater without a timer. Oh and 24 hours here would be $3.36 a day.
Old Feb 7, 2011 | 04:51 PM
HKusp's Avatar
HKusp
Mine starts after cycling the GP's for 60 seconds on 15w40 Rotella every time. There's no "need" for that block heater until you are in the single digits and even then, I don't plug mine in and she starts, it's nice to keep that oil thin and certainly helps with wear when the oil is thick, but the truck should start with no problems if the GP's are working properly.
