Got Any Code Reader Recomendations?
Old Feb 6, 2011 | 03:37 PM
Opossum's Avatar
Opossum
Question Got Any Code Reader Recomendations?
It looks like My brother or I need to by a code reader that will work on his 7.3 Powerstroke, my cheepo one won't work on it and I'm told many cheepo ones won't work well with these.
Any recomendations, what do you have? would you recomend it? etc?
Thanks
Old Feb 6, 2011 | 03:42 PM
empiretc's Avatar
empiretc
Snap-on or autoenginuity
Old Feb 6, 2011 | 03:50 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
AE from Clay at Riffraff. It's the best, runs alot of diagnostics others won't run.
Old Feb 6, 2011 | 03:55 PM
Opossum's Avatar
Opossum
AE is Autoenginuity? Like what and does it really matter?
The next logical thought is to kill 2 birds with one stone and get a tuner with code reader functions. Any recomendations there? Do the tuners do a poor job with codes and other info, or a better job cause they have a live constant hookup and display?
Money is tight but if well spent we can work it out.
It's an '02 with a manual tranny.
Old Feb 6, 2011 | 04:39 PM
woodnthings's Avatar
woodnthings
AE can run the various tests that are required to diagnose your truck. Code readers and tuners only read codes which will help, but may not solve the the problem. AE can pull live data from all the sensors and really helps when troubleshooting. The testing varies depending on what vehicle you use it on. Your PS often requires the injector buzz test as well as cylinder contribution. There are many others that can be run. It also has the ability to change the speedometer for larger tires. Really it is the best deal out there. I have had mine for several years and it is really nice to have.
Old Feb 6, 2011 | 04:51 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
What Ken said!!!^^^^^^^^^^^^^^^
Old Feb 6, 2011 | 04:53 PM
diesel-fitter-bum01
What Ken said.
Old Feb 6, 2011 | 05:07 PM
big poppa's Avatar
big poppa
AE like Ken mentioned is king, everything you need for a (complete) diagnosis. A Superchips handheld tuner is another option for yaa. Their code reading ability is worth more in my opinion than HP numbers, although the modest power gains and shifting stratagies worked for me at the time. Buying a used one can be had here and there, look around..
Old Feb 6, 2011 | 05:22 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Another vote for AE. Its awesome!
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
Old Feb 6, 2011 | 05:25 PM
woodnthings
If you really just want codes read checkout this reader from Strickly Diesel. They only have the one but it is cheap.
Cheap Code Reader
If you want codes read and you want to check out AE, PM me and you can bring your rig up to my shop and I will run the diagnostics for you.
Old Feb 6, 2011 | 05:27 PM
big poppa's Avatar
big poppa
What an offer, nice going Ken, reps when I can...
Old Feb 6, 2011 | 06:46 PM
fragglerock's Avatar
fragglerock
how much is the AE cost and where do i buy one
Old Feb 6, 2011 | 07:03 PM
megawatt00's Avatar
megawatt00
Originally Posted by weekendwarriorfsw32
Nick posted the link for you
Old Feb 6, 2011 | 07:08 PM
woodnthings
Thanks Mike! I figure it is the least I can do for someone who is in my area!
Old Feb 6, 2011 | 07:09 PM
SkySkiJason's Avatar
SkySkiJason
AE $360 from Riffraff Diesel
The Ultragauge looks like a cheap code reader that displays engine parameters - and its only $59
UltraGauge Automotive Information Center and OBDII Scan Tool
I have a Scangauge II that is similar, but its $169
ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
I wish these turkeys would get their act together. This fits in a gauge hole, displays any engine parameters PCM monitors AND does diagnostic tests like Buzz Test, etc.
Aeroforce Technology Inc | Products - Interceptor
