headlight switch
Old Feb 6, 2011 | 07:20 AM
deljac's Avatar
deljac
headlight switch
i just bought a 95 f150 extended 4x4. i got into it the other morning and when i started it up the park and taillights came on, if i turn the headlight *** they dim then shut off and when i pull the switch they work normal, is this how its suppose to be, ive owned alot of ford trucks thru the years and never seen this before
Old Feb 6, 2011 | 09:11 AM
rikard's Avatar
rikard
That doesn't sound normal. I would pull the switch and check for continuity and burn marks. I had to replace the switch and connector on my 83 and just the switch on my 94.
Check your ground wires too, bad grounds can cause weird electrical behavior. The headlight ground wire on the radiator support has come loose on a couple of my Fords.
regards
rikard
mustangpt
Apr 22, 2015 09:59 PM
4fords
Electrical Systems/Wiring
Jul 16, 2014 02:17 PM
HowieE
Nov 11, 2009 11:07 PM
apbtpetey
Dec 1, 2008 02:18 PM
STiNGeRX
1983 - 2012 Ranger & B-Series
Jun 8, 2001 10:06 PM
