Another 2006 4x4 not working
Old Feb 6, 2011 | 12:18 AM
Hatter's Avatar
Hatter
I read other threads with this problem but mine is a little different. Everyone else says that the lights dont come on but my 4h and 4L lights do come on. It is exactly as someone else stated in another thread but it wasn't the original question so I thought I would start a new thread.
this is the situation:
Originally Posted by jaredrobertson
I've got a similar situation with the 4x4 on my 04 fx4. When i shift the switch on the dash, the corresponding lights come on correctly. 4hi light works and stays on but the front end will not engage. still in 2wd. ok if i put it in neutral, and shift to 4lo and put it back in drive, The 4lo light comes on, the gear reduction is present, but still no front tires turning. What do yall think? I've seen all these complaints about the 4x4 not working but most of them say that the lights wont come on. All my lights work good and the transfer case shifts to a lower gear but i still have no spinning. I havent tried anything yet. figured id wait and see what you guys thought.
I hear noise when I turn the switch but the front tires do not spin
Mine is a 2006 xlt, on the fly
Any help would be appreciated
Old Mar 9, 2011 | 10:17 PM
48fordjeffie's Avatar
48fordjeffie
Hi,
I'm sure you have this solved by now, but just in case you don't. My lights did not come on. I had to have a new switch put in. It was not cheap and I thought it would be covered but surprise, it wasn't. Since when is the 4x4 not part of the drive train? I was told by a retired Ford mechanic to switch it into 4 high/low once a week and that should help.
Good luck...
Jeff
rmkeith
2004 - 2008 F150
Mar 24, 2014 01:03 PM
hhansen59
Jul 6, 2011 04:53 PM
robles4242
61
Feb 16, 2010 11:50 PM
boggerted
Feb 7, 2008 03:27 PM
GMCfourX4
1997 - 2003 F150
Apr 9, 2007 10:06 PM
