2000 ranger....hiccup?
Old Feb 5, 2011 | 12:38 PM
Otahyoni's Avatar
Otahyoni
Hello everyone. Just picked up a 2000 Ranger with 215xxx on it. 2.5L and a 5 speed.
When i was driving it home i noticed a hiccup. Like it cuts out for a split second then comes back to life... Seems to only do it under a light load, as when i'm cruising...
Also, when i was leaving the parts store I started it then it died and wouldn't restart. It took several tries before it would start again.
Any ideas?
I got stuff to do a tune-up, hoping that it helps... Plug wires kinda look OEM...
Old Feb 5, 2011 | 12:49 PM
03 Maz B23's Avatar
03 Maz B23
In addition to tuneup clean MAF sensor (in air intake near air filter housing) with electrical contact cleaner and replace gas filter.
Old Feb 5, 2011 | 01:34 PM
Otahyoni's Avatar
Otahyoni
Fuel filter is in the box, but i hadn't thought about the MAF sensor.
Procedure?
Old Feb 5, 2011 | 02:21 PM
Otahyoni's Avatar
Otahyoni
Looking at it i noticed that the rear-most cylinder, the exhaust manifold is cracked all the way around.
If this something i need to be concerned with, or just leave it alone?
Old Feb 5, 2011 | 06:23 PM
03 Maz B23's Avatar
03 Maz B23
Here is link on MAP sensor cleaning procedure. I recommend it for general maintenance in case it hasn't been performed in awhile. Your symptom sounds like a spark plug misfire issue which replacement should hopefully correct.
Ford Ranger Mass Air Flow Cleaning, Removal and Installation
Old Feb 6, 2011 | 12:20 AM
Otahyoni's Avatar
Otahyoni
Thanks, Maz. I saw that after i asked...
Any word on the exhaust manifold?
And another thing, can i recalibrate my speedometer for a new tire size? The P.O. put slightly oversize tires on very recently so i'd like to adjust the speedo instead of replacing already new tires. I know theres a limit to the amount of times it can be changed (at least on my 93 F150).
They went from a factory 225/70-R15 to 235/70-R15. I think it's about 2% off now... (60mph=61.4mph)
Old Feb 6, 2011 | 06:09 AM
03 Maz B23's Avatar
03 Maz B23
Never dealt with speedo recalibrating so can't offer any input. If it were mine would leave it alone as it's such a small error. On the manifold probably should replace it for safety but after all those miles those studs/bolts probably would be a bear to get loose which is probably why it was never replaced prior.
Old Feb 6, 2011 | 06:28 AM
03 Maz B23's Avatar
03 Maz B23
Here is link for replacement exhaust manifold from ford. Pricey. Might be able to get aftermarket/junkyard (might not be any better than what have) but didn't see anything online when i did search.
Exhaust Manifold | FordParts.com
Old Feb 6, 2011 | 08:34 AM
Otahyoni's Avatar
Otahyoni
I think as far as the manifold goes, i'm going to try either JB Weld, or the parts store muffler repair goop... I don't want to mess with it for fear of breaking a bolt off in the head...
Old Feb 6, 2011 | 02:50 PM
michigan66's Avatar
michigan66
Your Ford dealer or a speedometer shop can get you the correct gear to correct your speedo to go with the bigger tires altho I am inclined to agree with 03 Maz B23. Leave it as is.
SwampFox112
Sep 12, 2016 10:15 PM
kthemurphy
16
Jul 16, 2016 10:12 PM
97-350
Jun 22, 2016 02:34 PM
jpen365
Sep 4, 2015 07:24 AM
Reckless
Apr 7, 2011 02:41 PM
