K got my dana 60. Going to clean it up and paint it and throw it in. I would like to get a RSK aswell. So ive been reading up and was told if i get a 4" RSK i can put 4" F350 blocks out back and get a level 4" lift all the way around.....this true? If so what year truck do i get the 4'' blocks from? Thanks
I gather it does level out closely. I know depending on what type of front suspension you have going on up front (250hd, or 350) can differ slightly. As for the rear blocks, you can use models as early as 89 and up.
Yup, the 4" rear blocks are going to be ideal for leveling out yours.. Its what I had to mine when I used the 250hd springs and RSK. I was amazed at how much lift came from that! You will need to see about getting longer U-Bolts for the rear axle, unless you find them on the 350 somewhere, but just in case, FTE safety reminder is to "not re-use U-bolts, technically we are to get new ones", LOL! You could also go to your local steel supply shop and "home make" some blocks as well if you cant find em!
Any idea on which rsk to use? ive been told that the d60 adds two inchs of lift upfront. So do i get a 3 and use my 4 inch blocks in rear? im confused!!
Sorry.. cant help you there just yet.. give me a couple weeks, LOL! In the process of fighting with leveling out mine from the RSK type install.. I ended up with some serious lift.. I should see if I can get some pics posted!
[quote=Krisx125;9929103]Any idea on which rsk to use? ive been told that the d60 adds two inchs of lift upfront. So do i get a 3 and use my 4 inch blocks in rear? im confused!![/quote i dont have a rsk on my truck, but have seen a 350, sets 2 in higher than a 250 stock. didn no that, so if you look at my truck it sets 2 in lower in the ***, i did a 6 in sky jacker with fitted leaf in the front,so wuld say with sping settaled in and all iam at 8in or so of lift in the front, and the back was planing on kedp in my rake, so left the 2in add aleaf wich you get about an in out of 5 inblock that came in kit, so with the 6 in over stock in the rear useing 250 block iam short 2 in, i got my lift for a 350 cuse i new the d60 was going in, sorry so long not even sur if i helped lol
