Head removal?
Old Feb 2, 2011 | 04:40 PM
ttexastim's Avatar
ttexastim
Head removal?
Hey guys. So ... last time I posted, I had 3 broken GP's stuck in the head. The 5 GPs I did have, were working good. Then ... they stopped working so good. One of the 5 GP's went out. Turns out ... it was the last "Champion" brand that the previous owner put in. (I figure this was probably due to only 5 GP's having the 12 volts applied, leading to a bit of over voltage maybe). Needless to say ... yup ... that tip broke off as well.
After a few expletives were let out, I tried to think of what needs to happen. 3 of the burned out plugs, are on the driver side block.
So ... how big a job is it to pull a head on a 6.9 diesel? I've done most things on trucks, but I've never mucked around with timing or removed a head. I consider myself to be pretty handy. How hard a job is it to remove a head? I'm considering doing it. It's either that or it's time to sell the truck and get a newer one.
Old Feb 2, 2011 | 04:57 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Isn't as bad as some say it is, i've done it on my 6.9 in a VAN! I replaced both head gaskets.
Keep in mind the heads weigh 125lbs each....
You have to remove all the metal high pressure fuel lines, without bending any. It's a job, but if it's gotta be done, it's gotta be done!
snowcrash47
22
May 2, 2012 01:26 PM
38Chevy454
Dec 16, 2010 08:31 AM
ttexastim
Dec 8, 2010 11:12 AM
lovefordtrucks
Nov 29, 2010 07:35 AM
WarOzz
Jan 17, 2010 10:10 PM
