hpx. any pics?
Old Feb 2, 2011 | 01:28 PM
JonathanN's Avatar
JonathanN
Originally Posted by cj45lc
Does it do anything or do you think it's doing anything?
I think it's worth it... clatter is gone some, but I have other things making too much noise to really tell. The HPx made a world of difference in how smooth it was, especially at idle. The FRx gave me more low-end torque than I had so I know that was worth it...
Old Feb 2, 2011 | 01:33 PM
cj45lc's Avatar
cj45lc
Thank you for your opinion, I've heard mixed reviews
Old Feb 2, 2011 | 01:48 PM
snakedoc's Avatar
snakedoc
i did the same as JonathanN, hose for Car Quest. as for a lot of difference i did not see that much, but my truck idles very good before the hxp.
Old Feb 2, 2011 | 07:01 PM
bcaughhorn's Avatar
bcaughhorn
thanks for the pics. alot easier to see on the computer
Old Feb 21, 2011 | 04:42 PM
rebelmdb's Avatar
rebelmdb
Just ordered mine from Clay. Will do it next week when it gets here.
Old Feb 21, 2011 | 05:56 PM
Bonanza35's Avatar
Bonanza35
Originally Posted by Kwikkordead
Does this help?
Dan got the same set up from my neighbor.He went banks and said I could have for $25. Had to buy. How tight did you make the fitting on the block.They have o-rings I think, do you put ten lbs or so or real tight. Your help would be appreciated, Chet KCN SS
Old Feb 21, 2011 | 06:12 PM
woodnthings's Avatar
woodnthings
It helps balance out the oil pressure in the heads. It is not something you will see or feel necessarily, but you may be able to hear that the idle is smoother and quieter depending on the truck. When I installed mine it seemed to be smoother, but maybe I was just thinking that to justify the purchase
Without some test equipment to measure the before and after, it is hard to really define the difference.
Old Feb 21, 2011 | 06:16 PM
woodnthings
The fittings in the head do not need to be super tight. The o-rings provide the seal and if over torqued, they can deform and leak. As far as the tube fittings I tighten them by hand, then an additional 1-1/2-2 turns. The flare-less ferrule on the tube can be damaged from over tightening.
Here are the instructions: KCM INSTRUCTIONS
Old Feb 22, 2011 | 12:06 AM
Bonanza35's Avatar
Bonanza35
Ken thanks for the reply. I figured as much but I have a tendency to over torq things so I hope I do it right. I'm also puting on a t.5 HPOP since my e99 has a 15.
Chet
Walleye Hunter
16
Sep 12, 2016 01:47 PM
Km1210
82
Apr 27, 2016 02:52 PM
Atc210
Apr 4, 2013 05:17 PM
jg96powerstroker
May 23, 2011 05:54 AM
Texas Outlaw
58
Aug 15, 2010 04:02 PM
