Where can you find clear blinker lens an after market headlight kit all i can find is just the stock blinkers an i found some glass halogen converstion kits at napa but i dont know if theyll fit. any susuggestion or websites will help. Also i have a 302 it got a high idle an i adjust the adjuster screw most of my sensors are kinda old should i replace my o2 sensors an tps sensor or is there something else. also it some times has a miss fire known of my wires or plugs are bad or disconected an there not sparking off eatchother. it happened after took my intake manifold of an re enstaled a it. maybe there is a bad sensor im not sure though either.
I found my clear corners on ebay, they are hard to find. The ones I got were not the greatest quality, I kept my factory lenses just in case these ones fell apart. I did have to resilicone the lenses to the housings because they started to leak..
