1978 - 1996 Big Bronco
blinkers not blinking
Old Mar 9, 2007 | 01:04 PM
nelly781's Avatar
nelly781
i turn on my blinkers in my 88 5.0, and they turn on, but no blinking, is this just the blinker timer gone bad???
Old Mar 9, 2007 | 01:36 PM
mprice's Avatar
mprice
Probably, and since that's only a few dollars to swap I would change the blinker module first.
The other more complicated possibility is that the blinker module isn't getting enough voltage. The module's electronics require a minimum voltage to operate the switching. If you have a meter check to make sure that the blinker module contacts at the fuse box are getting about 14V with the hazards turned on that the truck running. Also watch the dash volt-meter to make sure that the whole truck is getting enough juice.
Old Mar 9, 2007 | 01:54 PM
renegade734's Avatar
renegade734
Check exterior bulbs before spending the money on a new flasher.
Old Mar 11, 2007 | 06:23 AM
Will_01_GT's Avatar
Will_01_GT
The flashers maybe $3.00, change it and all the bulbs at the same time, its spring time in CT. Hope it a great day for every one, I'm in the mood to clean up and tune up my Bronco !
Unrealo4
Jul 22, 2012 08:45 PM
CanadianBigBlue460
Apr 17, 2010 06:33 PM
Fishin76
Jan 6, 2010 08:34 PM
dirtyoldrat
Apr 19, 2009 11:41 AM
mrsmom298
Electrical Systems/Wiring
Jan 8, 2004 11:07 AM
