Strange steering noise (hissing/gurgle) at 1/4 turn?
Looking for suggestions on this before it becomes a major problem:
I was driving my '73 F100 in a parking lot today and noticed when the wheel was turned about 1/4 (90 degres from center) I heard a soft hissing noise. It occurred in either direction of wheel travel. The more I turned the wheel the worse it got until near full lock, then it stops. If I turn the wheel, shift into Neutral, then rev the engine a bit, I hear the hissing/gurrgling get louder and can feel the steering wheel pull a bit. So far normal steering has not been effect and the truck it still driving fine.
I don't know if it has always done this and I never noticed or if this is new. I replaced the Power Steering pump (NAPA) and power steering hose (Advance) back in November. I checked and there was a decent amount of fluid in the resevoir. Thoughts on this? My fear is that something has started to wear out with the hydraulic cylinder...what symptoms does that usually give?
thechainsawman
11-15-2016 10:46 AM
neller840
04-21-2015 08:54 AM
SageofHalo
2004 - 2008 F150
06-20-2014 06:04 AM
