transmission hiss sound in reverse - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 09-18-2012, 01:07 PM
9902ford 9902ford is offline
9902ford is starting off with a positive reputation.
Hello,
I have a 2002 2wd expedition with a 5.4 triton. Just recently i have noticed that when it is put in reverse there is like a hiss type sound. Now when my wife was pulling out of the driveway the hiss sound was a bit louder and it sort of smelled like air. The smell was like air just let out of a tire. Now when it is put in drive, everything is normal. I have not had a chance to look at it just wanted to get this question out there to get some help.
Thank you
Old 10-08-2012, 12:34 PM
toorodeo toorodeo is offline
toorodeo is starting off with a positive reputation.
same issue
I have the same issue. When I put my 2001 expedition in reverese only I get a hissing noise comming from under the truck everything runs great just a ?
Old 11-13-2017, 12:37 PM
DOAT DOAT is offline
DOAT is starting off with a positive reputation.
Air sound at steering wheel
Okay, so I know what everybody's talking about with the hissing sound in the steering wheel when you turn it all the way, or sometimes at all. Mine was doing that, had started and did it for a while I ended up changing the power steering fluid, still did it but helped a little ended up getting Lucas power steering conditioner, pulled some of the fluid out and poured it in. Immediate fix! Barely does it at all now, and the brakes are much more responsive. I still have the hissing sound in the tranny in Reverse though...
Old 11-13-2017, 07:19 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
Interesting trick that putting conditioner in your power steering box made the brakes more responsive.
Old 11-13-2017, 07:43 PM
Quote:
The power steering pump is not only power steering, but it supplies the power boost for the brakes. So any problem with the pump will affect the brakes.
Old 11-14-2017, 01:39 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
Didnít know that. What year(s) Expeditions had that?
Old 11-14-2017, 03:52 PM
I don't think any did, Expeditions all use vacuum boosters. He is referring to hydraulic boosters.
"The hydraulic pressure generated by the power steering pump is stored in an accumulator, which is then routed to the master cylinder by the hydraulic booster unit when the brake pedal is applied"
Hissing noise BGMSPD 2017+ Super Duty 18 08-15-2017 02:02 PM
New Hiss under hood silverbullet6oh 6.0L Power Stroke Diesel 55 08-26-2016 11:59 AM
Loud air sound up front Headviking 6.0L Power Stroke Diesel 5 06-18-2015 07:43 PM
New 4"MBRP install and hissing noise from exhaust Pridnjoy 6.0L Power Stroke Diesel 8 09-07-2013 09:50 PM
'91 4.0 loud hissing sound exp 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 5 04-14-2004 05:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
