Forgot to plug in, won't start, but it is 5 hours later.
I plug in my truck, but forgot to last night and it was 5 degrees fahrenheit this morning and would not start. Yesterday it started, after being plugged in, it was 10 degrees warmer, but died and started right up again. It has never done that before
Background, 115,000 miles. Maybe 1,000 mile on fuel filters and Rotella T 5w 40 synthetic. New batteries, alternator and serp belt.
Now I have had it plugged in for 5 hours, it turns over fast, pops after a couple seconds, then just turns over. I have tried cycling the key a few times; leaving the key on until I hear the end of, maybe, the fuel pump. The water in the fuel light stays on, but so do other lights, until it starts, should it?
What is going on?
What is going on?
Check for water in the fuel pump out the brass drain plug on the fuel pump.
Could your fuel be gelling? Really shouldn't be with where you live, Their fuel should already be good down to those temps. But who knows. Do you treat your fuel?
FICM: might be loose again?
ICP on your model year is here:
No solution for you, but for most of this winter I have NOT plugged in my 6.0, and have had temps down to zero without starting issues here in Northern Ohio. She does start much easier and smoother initial idle when plugged in......you may have some gelling or water issues in the fuel that maybe froze in the filter(s) or lines....but just a guess.
Still won't start, but it "popped" twice this morning, wish I could get it in somewhere warm, it is 6 below fahrenheit. I think, hope there is just water in the fuel line. I had it plugged in for 24 hours and a heater overnight, but it is just too cold.
It will be about 30 in a couple days, I put some diesel 911 in the tank. What else can I do? I checked FICM connects, don't know how to check the voltage of it. But I think it is too big of a coincidence that it won't start on the coldest morning for a couple weeks, and I forgot to plug it in.
Happened to me last winter. I was back home in Detroit, driving downtown at night (temp was 4 degrees) and she just shut off on me and wouldn't restart. Did the same thing yours is doing now. I was freakin because I though she blew a gasket. Had a buddy of mine check her out and it turned out that the fuel had gelled past the filter (top side) before the injectors. I put some anti-gel in the tank and in the filter housing. let it sit and she started right up. I can't remember the name of it, but its in a red bottle...! 911 something!? I think it was something like that.
Open the top of the secondary fuel filter on the top of the motor and see if you have liquid fuel in there.
My bet is a frozen fuel line. You could take a hair dryer and leave it on the top of the motor for a few hours to thaw things out. Just be careful not to burn anything sensitive.
Happened to me back in the 80's with a chebby. The mechanic said to get one of those blankets you put over the grill like this...
Cabela's: Winter/Summer Truck Grille Covers
I use it when it gets really cold here (but not as cold as you get!) It also helps the heater to warm up faster!
If it is gel, plugging in for that long, the engine should be fairly warm and might be the reason it "popped". Fuel at the top was warmed enough to get some flow to injectors. The fuel from the pump however would probably still be gelled. Pull cap on top filter and see if there is any gel in there (as was suggested) and crank to see if fuel will even flow to the upper filter. Heck you could even through an old sleeping bag over the engine to help keep heat in there. But it wont help the lower fuel lines and such. Find the Power Service 911 and do as suggested above.
Pull the lower fuel filter. If it's gelled, it will be there.
Man, I hate doing this kind of stuff in those temps. I don't envy you at all. Stay warm!
FICM test link:
https://www.ford-trucks.com/forums/8...procedure.html
p.s. keep an eye on your batteries! Might want to give them a charge. Even if you wait out this cold snap.
FICM test link:
