428 HEADERS
Old Feb 1, 2011 | 10:37 AM
RANGER589's Avatar
RANGER589
428 HEADERS
I have a 72 F250 W/ 428, C6 and custom Stainless dual exhaust ( Nascar style? ) with both sides exiting on the passenger side behind the axle. Standard manifolds.
1. I would like to get headers for it. Anyone know a good resource for this application?
2. When I changed the oil I was surprised to find I couldn't use the Fram filter I used on my 65 F100 with a 390. The clearance from the filter mount to the cross member was about a half inch too tight. I thought it would be the same? The engine / chassis appearance doesn't look any different from the 65 pictures I still have?
What could be the difference here?
Is it a chassis difference due to year or tonnage rating?
Also, The oil pan drain bolt is smack center of the cross member. Makes oil changes messier than they should be. Will a 390 truck application pan fit on a 428?
Thanks guys.
Old Feb 1, 2011 | 11:59 AM
Bear 45/70's Avatar
Bear 45/70
Can't help with the headers, but the oil filter problem is easy to fix. Get the truck oil filter mount and then instead of down the filter will be horizontal. Or you can just put a jack on the front lip of the oil pan and jack the motor up an inch or so and get the filter off. At least that always worked for me. On the oil pan I used a deep sump unit and the cross member was not an issue.
Old Feb 2, 2011 | 09:02 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The oil pan, you can definitely swap to a truck pan, it will bolt up, just make sure you get the correct oil pickup tube.
Bear has you covered with the oil filter adapter. Is your F250 4x4, or 4x2? My '74 highboy had a vertical oil filter adapter and there was no problem with the oil filter. Are you using a PH8A filter or the longer HP filter?
Headers - what bolt pattern is on the 428 heads? Standard 8-bolt? If not, it's gonna be hard to find anything except "shorties" that MIGHT work. If it's the standard 8-bolt exhaust bolt pattern, find the correct headers for a 360/390 for your year truck and you should be good to go. Just make sure the ports match up before you get all into it
Old Feb 8, 2011 | 06:50 AM
RANGER589's Avatar
RANGER589
Thanks for the info!
Old Feb 8, 2011 | 07:11 AM
RANGER589's Avatar
RANGER589
Thanks Krewat. I'll check the bolt pattern. Any input on best place to get a set if I can use them?
Old Feb 8, 2011 | 08:47 AM
69cj's Avatar
69cj
It's none of my business and just my op but if you like your motor I would upgrade to a better quality filter than Fram.
Old Feb 8, 2011 | 09:10 AM
427 fordman's Avatar
427 fordman
I'd agree with that.
Old Feb 9, 2011 | 07:25 AM
RANGER589's Avatar
RANGER589
What do you guys recommend?
Old Feb 9, 2011 | 08:56 AM
69cj's Avatar
69cj
Mobil 1, purolator, bosch, moptorcraft to name a few.
joogie22
Nov 15, 2011 06:29 PM
OrangeJuice
Jul 28, 2010 08:55 PM
FordTrucksKickGM
15
Oct 31, 2008 04:03 PM
Ford150/428/dud
Engine Swaps
Apr 9, 2005 06:54 PM
pward76
Dec 10, 2002 03:45 AM
