911 help.....
Old Feb 1, 2011 | 04:22 PM
nissandoc's Avatar
nissandoc
Yes. Or you can just hook it up to one of the batteries.
Old Feb 1, 2011 | 04:23 PM
SkySkiJason's Avatar
SkySkiJason
Originally Posted by roostercrows
Thanks Darrell, so to test the alt. I put the meter to the positive and negative on the on the alt.? My truck didn't come with the in dash voltmeter.
Voltage at either battery will tell ya what you need to know.
Old Feb 1, 2011 | 04:24 PM
SkySkiJason
I
t y p e
s l o w...
Old Feb 1, 2011 | 07:27 PM
roostercrows's Avatar
roostercrows
Ok, I checked the alt. wires and they all seem fine, the battery test I'm gonna have to wait until tomorrow, its too cold out.....
Old Feb 1, 2011 | 07:50 PM
nissandoc's Avatar
nissandoc
Guess I should have clarified. Take voltage readings at idle with all loads off. Then turn loads on and check the readings again. You can also check the readings at 2k rpm's. If your readings dont change or are lower with a load, the alternator is toast.
Old Feb 3, 2011 | 08:59 PM
roostercrows
Ok, so I was able to test the voltage tonight and it is 17!!!!! I think that is burning out my batteries too! Does anyone know if the regulator is separate from the alt. or is it all in one?
Old Feb 3, 2011 | 09:00 PM
roostercrows
Also is there an upgrade alt. or should I just get the same as factory?
Old Feb 3, 2011 | 09:25 PM
nissandoc's Avatar
nissandoc
All in one.
There are some higher amp alternators out there. Cant think of the name of them right now. Maybe someone will chime in.
Old Feb 3, 2011 | 09:35 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
One of the guys on here did a IIRC 160amp up grade It was F250_
Here's his thread = https://www.ford-trucks.com/forums/9...-and-pics.html
Vance77
1997 - 2003 F150
Jul 20, 2014 06:52 AM
madmann
2004 - 2008 F150
Mar 5, 2011 03:01 PM
03-exp
Modular V8 (4.6L, 5.4L)
May 19, 2010 06:14 PM
Redmanbob
Nov 27, 2005 12:01 AM
kenpep2
Electrical Systems/Wiring
Sep 28, 2003 07:37 PM
