911 help.....
Old Feb 1, 2011 | 06:44 AM
roostercrows's Avatar
roostercrows
911 help.....
Hey guys, as I was driving in this morning and about 2 mins after starting the truck my dash went dead. All of my guages went to 0, fuel, oil pressure, tranny temp, oil temp, tach, speedo and even the odometer is blank. The ABS light came on as did the battery light, the dash lights worked and the truck worked fine? Occasionally it would all go back to normal for about 2-3 seconds about half way through my drive, but by the time I arrived it hadn't come on in 10 mins. Has this happened to anyone else? Can anyone give me a (hopefully) simple answer to this?
Thanks so much for any input!
Old Feb 1, 2011 | 07:00 AM
riverrat41's Avatar
riverrat41
I am thinking a bad fuse and I bet you are to but it does not explain the coming on for segments and them going off for good?
Old Feb 1, 2011 | 07:36 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Just a dumb question, but did you try the old 'smack the top of the dash fix'? Because if it is a loose connector, you might jiggle it into working, then you know all you have to do is pull the cluster and make sure that huge plug is in there tight.
Old Feb 1, 2011 | 07:52 AM
Kwikkordead's Avatar
Kwikkordead
Water dripping on the GEM?
Old Feb 1, 2011 | 08:09 AM
Franko72's Avatar
Franko72
Molon Labe
X2...check for moisture
Old Feb 1, 2011 | 08:24 AM
jetdoc's Avatar
jetdoc
Ahhhh...The old "technical tap"...
Old Feb 1, 2011 | 09:03 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
That sounds like the alternator crapped out on you. That is what has happened to me when mine went out.
Old Feb 1, 2011 | 12:41 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
There are two connectors on the back side that have possibly come loose. Pull your dash apart then the four 8mm screws need to come out. Push the connectors back together to the cluster. Should all work again.
Old Feb 1, 2011 | 03:43 PM
roostercrows
Hey guys sorry I took so long for an update, and thank you for all the replies!
Ok, on my way home it pretty much did the exact same thing, only I noticed that it would shut down only when I accelerated past 1000 RPM's, and would only come back on when my braking speed got below 20ish mph. Really weird.
Does that sound like it could be the plug still?
If so, how do I take apart the dash?
"Kwikkordead Water dripping on the GEM?"
I doubt it would be water, even though I don't know what the GEM is, because its been well below 0 here for weeks.
I was hoping that it would be a fuse, but think that is unlikely due to the on/off effect.
The alternator is my worst case scenario, although timing wise it would fit.....I just replaced the starter and all the brakes.....
Old Feb 1, 2011 | 04:01 PM
roostercrows
oh and another thing I noticed was the windows and locks did not work when the dash was out?
Old Feb 1, 2011 | 04:10 PM
nissandoc's Avatar
nissandoc
No GEM on an 03.
You can test your alternator under load by turned on the headlights to highbeam, turn blower fan on high and see what the output voltage is from the alternator. Compare those readings to what it is at idle and you will know if its doing its job.
Low voltage will do wicked things with an electrical system.
Old Feb 1, 2011 | 04:12 PM
mxracer3276's Avatar
mxracer3276
This may be a stupid reply, but i had the same exact problem happening to me for the longest time and i tried everything. So one day it was doing it consistently so a buddy and i looked underneath the hood and he noticed that the plug on the top of the alternator was just sitting in the connector not actually plugged in. So we plugged it back in fully and it never happened again. Not saying this is the answer, jsut something to check out.
Old Feb 1, 2011 | 04:15 PM
mxracer3276
Totally didnt see that someone already said what i had mentioned!!
Old Feb 1, 2011 | 04:18 PM
roostercrows
Thanks Darrell, so to test the alt. I put the meter to the positive and negative on the on the alt.? My truck didn't come with the in dash voltmeter.
Old Feb 1, 2011 | 04:22 PM
roostercrows
Thanks Matt I'll go check that right now.
