looking at buying
Old Jan 31, 2011 | 02:28 PM
matejcekautoworks's Avatar
matejcekautoworks
looking at buying
hey guys, i haven't been on here in years lol. i'm looking a t buying a 1992-1996 f150-250 with either the 5.0 engine or 5.8 engine. auto, and 4x4 and extended cab.
what i'm looking for is how to read the vin/door tag to see if it has the best trans, transfer case and gears and if its LS or not.
i have searched for something like this, but cant for the life of me find a break down of the door tag.
also whats the best combo i could find?
any rare options to look out for?
any problem areas to look at/test/avoid?
thx guys.
Old Jan 31, 2011 | 02:44 PM
SideWinder4.9l's Avatar
SideWinder4.9l
First and foremost- Check maintenance records!
Ummm....on the door sticker it will say Axle-18, 19, etc
Axle codes 18 and 19 are 3.08 OPEN DIFFERENTIALS
a H will indicate a LS Dif IIRC...It'll read H35, etc....
There ya go....That clears up the differential questions....
And that clears up how to read the VIN #......The sequence numbers are just what # the truck is....
As far as rare combo's-
IIRC there was someone on here said there was a LS FRONT Diff.....Not sure on that one though...
Hope this helps-
-Wes
Old Jan 31, 2011 | 03:00 PM
matejcekautoworks
thx man, whats the trans and transfer case code's? again, thx
Old Jan 31, 2011 | 03:43 PM
SideWinder4.9l
Not for sure actually, never saw them that I can recall, but the info I gave ya should give you a good launch in your search....
Also-
If buying a dual tank truck, the rear tanks are usually bad to have issues....
-Wes
Old Jan 31, 2011 | 03:52 PM
matejcekautoworks
thx wes...
kythri
Aug 1, 2013 02:56 PM
6CylBill
13
May 16, 2012 04:32 PM
m4ximusprim3
Apr 16, 2012 01:28 PM
johnson2007
Aug 18, 2009 02:59 PM
Ultraboy
Jan 16, 2006 07:14 PM
