Heater Core Firewall Grommet
Old Jan 31, 2011 | 12:42 PM
LARIAT 85's Avatar
LARIAT 85
Is there supposed to be a grommet or rubber plug at the firewall of the engine compartment for the heater core pipes? I am talking about where the rubber hoses connect to the heater core. Mine doesn't have any sort of plug or cover, and it is somewhat loose and looks like something is missing there.
Old Jan 31, 2011 | 12:48 PM
glovemeister's Avatar
glovemeister
If you mean in the glovebox there is a cardboard type cover that restricts access to the heater core. If you mean under the hood then I don't believe so. It appears the core sticks out the holes into the engine bay and my hoses connect on. If you mean vaccumn lines under the glovebox then yes there is a couple grommets I noticed when I pulled my interior the other day, dash etc.
Old Jan 31, 2011 | 04:24 PM
Eddiec1564's Avatar
Eddiec1564
Yes there should be a foam gasket that fits over the heater core pipes. As time and heat takes its toll, it most likely fell apart. I used some RTV and inner tube rubber and made up a gasket to keep water/air leaks from occuring.
Don't use that expando foam. That stuff holds water and rots metal, found out the hard way....
Old Jan 31, 2011 | 04:57 PM
LARIAT 85's Avatar
LARIAT 85
Thanks, Eddie. I thought a gasket or grommet should be there.
Is this gasket just glued to the firewall? I don't see an indentation for it.
Old Jan 31, 2011 | 05:04 PM
Rogue_Wulff's Avatar
Rogue_Wulff
If the heater core has been replaced, the foam gasket is likely laying in the bottom of the case, or got tossed with the old heater core. If it's in the bottom of the case, it's usually in many tiny pieces......
Old Jan 31, 2011 | 05:38 PM
guindian28's Avatar
guindian28
I just replaced my heater core a couple weeks ago and the new one was too tight of a fit for the foam from the old one to fit
Old Feb 1, 2011 | 08:57 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There is a U shaped foam gasket that seals the heatercore to the box.
At the firewall of my 1987 the Factory had applied some mastic tape to seal the heater core necks on the engine side.
Old Feb 1, 2011 | 05:56 PM
Eddiec1564's Avatar
Eddiec1564
Here's what that gromet looks like, this is from a 87 up truck. The 86 older are not much bigger than heater core pipes shaped much like a figure "8"
That 87 up looks much better than the older ones. Only problem is you have to pull the heater box from the fire wall. Not a fun job, but can be done.
I forgot, I did find my fix, and will photo it if I can find it again.....found it.. Looks ugly but works, it's blue RTV and held up since 1992
another view of the 87 up
Chiver
1983 - 2012 Ranger & B-Series
Feb 8, 2017 01:31 PM
Mgjfam
Dec 22, 2016 03:23 PM
maverick600
Oct 27, 2016 06:35 PM
treverd
Mar 30, 2016 09:31 PM
Old Brown F250
Nov 2, 2010 07:15 PM
