Sponsored by: Auxito
2002 F150 FX4 clicking
Old Mar 9, 2003 | 09:53 PM
amcamx's Avatar
amcamx
Question 2002 F150 FX4 clicking
I am experiancing a relay type clicking noise around the instrument cluster/light switch area of the dash. It is itermitant and not sure what causes this. It is a rapid relay clicking. My 99 F150 4x4 started this just befor I got rid of it. Any one experiancing this?
Chuck
Houston, Texas
Old Mar 10, 2003 | 12:57 AM
Racerguy's Avatar
Racerguy
Any other symptoms? Everything works?
In behind the fuse box is the GEM module. There are relays in there and in the fuse box itself. Sometimes the windshield will leak and water will drip into the fuse box and GEM and can cause relays to click on and off when they arent supposed to. If you can figure out what relay is clicking on and off someone here can probably tell you what the relay is for and go from there. Is your truck still under warranty? Might want to take it in to get fixed.
Old Jul 21, 2024 | 06:13 PM
Fender714's Avatar
Fender714
1st Gear
Same problem with mine. Did you get any info?
ChuckHouston, Texas
Did you find any info about this?
hmedic
Nov 1, 2024 12:29 AM
truckerboy
Electrical Systems/Wiring
May 28, 2010 05:17 PM
RAMPAGE_F350
Jul 13, 2008 01:40 AM
konan
Jul 25, 2006 05:08 AM
73f100shortbed
Bronco II
Jul 18, 2006 06:50 PM
