Installed some cab lights today...
Old Mar 10, 2011 | 02:03 PM
  #31
Bonanza35's Avatar
Bonanza35
Originally Posted by JOHN2001
How was it doing the electrical when you installed it. My truck doesnt have them and Ive been wanting to put a set on since I got the truck. Do you run the wires to an existing spot in the cab, or is it like gauges where I had to run a hot wire to the battery? If anyone has pictures of the wiring that would be awesome.
I wondered about the atomic lights advertised on here with the strobe in them. Has anybody done these. I have lights already and just wondered about them. Seems strobes could come in handy sometime..
Chet
Old Mar 10, 2011 | 03:28 PM
  #32
HH60FE's Avatar
HH60FE
Isn't it amazing that this is a $55 option on 2011 trucks ! ! Dealer wants $400 to do this after the fact.
Old Mar 10, 2011 | 04:14 PM
  #33
PaysonPSD's Avatar
PaysonPSD
Nice work and template Greg. Reps sent.
Now I know who to come to for cab light help.
Old Mar 10, 2011 | 05:27 PM
  #34
Skip1970's Avatar
Skip1970
if you put the cab lights on backwards they would be more aerodynamic! hehehe might have to change the color of them tho.
Old Mar 10, 2011 | 06:07 PM
  #35
Ponyboychris's Avatar
Ponyboychris
Since I had the OEM harness, it was a breeze. The truck has a connection in the passenger side kickpanel already to go.
Old Mar 10, 2011 | 06:25 PM
  #36
Shake-N-Bake's Avatar
Shake-N-Bake
If you click on this link, you will find a nice write up about installing the lights. Down towards the bottom is a photo of the electrical connector you can use.
Mind's Cab Light Installation
If you have the overhead console, then that connector will already be occupied but all is not lost since there will still be two available spaces in the top portion. Just probe it with a test light and you will see which terminal is hot (the other is ground but verify with a ohm meter).
Hope this helps.
Old Mar 10, 2011 | 06:35 PM
  #37
JOHN2001's Avatar
JOHN2001
Thanks that's exactly what I was looking for. It might be time to buy myself another early Christmas present lol.
Old Mar 10, 2011 | 07:05 PM
  #38
Ponyboychris
You might want to check this out.
https://www.ford-trucks.com/forums/1...ab-lights.html
Old Mar 11, 2011 | 01:25 AM
  #39
Jaykane's Avatar
Jaykane
Urban Assault Vehicle!
I want to do these so bad but it puts knots in my gut thinking about drilling holes in my perfectly good roof!!
Old Mar 11, 2011 | 06:52 AM
  #40
Ponyboychris
I felt the same way but it's worth it. I love the look. Here's my writeup on this. Measure, measure, measure... Clearance Light install pictures from trucks photos on webshots
Old Mar 11, 2011 | 12:10 PM
  #41
Shake-N-Bake
I agree. It was tough to break out the drill and tear into a perfectly good roof. Was well worth it though...
I can't agree more. Measure, measure and then check everything several times. I especially like the template that Chris made (photo 104_2862 in his write up). You can also take that cardboard template and test fit one of your lights before you drill into the truck. It's a great double check.
In Chris's write up, he drilled a 7/8" dia hole between the two smaller mounting holes. In my case I had to drill 1 1/8" because the electrical connector would not fit a 7/8" hole (I tried but had to open up the hole using a larger step bit). I guess there might be a few different types of lights in circulation so check your set and use the appropriate hole size as necessary.
Old Mar 11, 2011 | 12:50 PM
  #42
twags6's Avatar
twags6
The first hole is the hardest one. You can do it though. I can't stress enough that you measure about 5 times before drilling though just to be sure everything is right. I masked the whole area of the roof with blue painters tape, marked out the holes with a sharpie, then set the lights on the marks to make sure it looked right.
Old Mar 11, 2011 | 08:46 PM
  #43
Jaykane's Avatar
Jaykane
Thanks for the confidence boost guys!! I think I will wait until spring to do this mod. Buy I agree it totaly makes the truck!!!
Old Jul 17, 2013 | 09:40 PM
  #44
ho_shi's Avatar
ho_shi
what was the install time? from first screw out until back in?
Old Jul 17, 2013 | 09:47 PM
  #45
kupaa's Avatar
kupaa
3 hrs working real slow
