i replaced my stock turbo with a e series ambulance turbo and it seems to spool a little faster? do the e series 6.0s use a bigger turbo like the 7.3s did or maybe my old turbo was just worn out btw it had 230000 on it so that could be the case
i wouldnt have a problem with that because i personally removed all of them from running trucks that were wrecked and the turbos worked fine so i could give a warrenty or something
yes 300-400 is well within the range for a 03. In fact if you have a few of them I could probably sell a couple of them for you real quick. As far as a warenty goes you wouldn't have to do that, other than to say that it is a working turbo. Garrenty that it works fine, or your money back, and you will be ok.
