Sponsored by: Auxito
glove box
Old Jan 28, 2011 | 08:46 PM
ford1960's Avatar
ford1960
glove box
I recently purchased a new glove box door for my 01' f150. I then realized that I needed a special tool. I have used something to keep the light off until I figure out how to use this "special" tool.
Please advise
Old Jan 29, 2011 | 07:38 AM
shorebird's Avatar
shorebird
Please advise us as to what the "special" tool is supposed to do.
Old Jan 30, 2011 | 11:21 AM
93 mix 'n match's Avatar
93 mix 'n match
umm.... no. all you have to do is pull the 2 clips together at the top, the box will fall all the way forward, then you pull it up from the bottom. they have arc-hinges at the bottom.
Old Jan 30, 2011 | 12:01 PM
steve(ill)'s Avatar
steve(ill)
i took mine out a couple years ago... seems like a phillips screwdrive for the door and maybe a pair of pliers ? The latch or light might be a little extra.
Old Jan 30, 2011 | 05:29 PM
ford1960's Avatar
ford1960
spring
I have the glove box spring tool set. How in the heck do you use it? pics please
Old Jan 30, 2011 | 05:30 PM
ford1960's Avatar
ford1960
the spring on the bottom of the box is the issue that im having with. it is a very heavy spring
Old Jan 30, 2011 | 09:03 PM
93 mix 'n match
......theres a spring?? not on my 97.... guess they changed it.
Old Jan 31, 2011 | 03:39 PM
ford1960's Avatar
ford1960
the special tool "glove box spring tool set" is fine if you are just taking the door off and putting it back off. I got a new door and am unable to open that spring what so ever. the bite that spring has is unreal.
ssj7kids
Jul 21, 2011 06:27 PM
emgee
May 10, 2009 11:57 AM
rlgx6
Jul 28, 2006 02:37 PM
cigarxtc
Oct 5, 2002 08:31 PM
starweb
Mar 30, 2002 10:14 PM
