Blue spring!
Old Jan 28, 2011 | 02:12 PM
mixerdrvr's Avatar
mixerdrvr
Blue spring!
Installed the blue spring the day after my fuel pressure gauge. had a new fuel pump 2 weeks ago but the great tech at the dealer didn't bother to check the pressure after the install. Had 50 idling ahd got down to 45 at around 2250. Now have 73 idiling and 65 at wot!!!
Old Jan 28, 2011 | 09:38 PM
smokersteve's Avatar
smokersteve
73 is a little high... not sure on what you can do about that.
Old Jan 29, 2011 | 01:20 PM
mixerdrvr's Avatar
mixerdrvr
According to ford all is good to 75.
Old Jan 29, 2011 | 01:33 PM
bismic's Avatar
bismic
lenzhotrod posted up the International spec on max fuel pressure in another forum. Their spec is 70 psig. IMO 73 is fine. I think that I am probably the main source for Fords spec. I documented it years ago and now I can not find the specific reference, but I certainly believe it to be accurate. Folks on the other forum I mentioned are debating whether or not the 100 psig from the GDS spring is really all that bad. Some people have been using it for 20k + miles and no issues yet. Who knows if or when you might see problems, but I do know that it doesn't get you anything ........ except more risk.
Old Jan 29, 2011 | 01:43 PM
mixerdrvr's Avatar
mixerdrvr
Originally Posted by bismic
lenzhotrod posted up the International spec on max fuel pressure in another forum. Their spec is 70 psig. IMO 73 is fine. I think that I am probably the mains source for Fords spec. I documented it years ago and now I can not find the reference, but I certainly believe it to be accurate. Folks on the other forum I mentioned are debating whether or not the 100 psig from the GDS spring is really all that bad. Some people have been using it for 20k + miles and no issues yet. Who knows if or when you might see problems, but I do know that it doesn't get you anything ........ except more risk.
I also got that from cheezit! I am sure it is correct! Not saying you are incorrect, just got from another very reliable source.
Old Jan 29, 2011 | 04:22 PM
cheezit's Avatar
cheezit
70psi is in spec. give the gauge 2-3 +/- psi. he is close enugh. being the spring is new it may settle a little bit as well.
hey Mark hows yoyr fuel pressure still holding at 68? iirc
Old Jan 29, 2011 | 04:45 PM
bismic's Avatar
bismic
Originally Posted by cheezit
hey Mark hows your fuel pressure still holding at 68? iirc
Last time I looked it was - very pleased! I now have the gauge on the degas bottle though. Will put it back to fuel next weekend.
Old Jan 29, 2011 | 08:23 PM
stroked4life's Avatar
stroked4life
blue spring
i just did the blue spring too. very easy as everone has described. i am around 68-69 psi. nice. i used the international part as it was only $30 instead of 60 or 80. doesnt come with the new outter cover, but who needs that. very happy $30 mod.
Old Jan 29, 2011 | 10:11 PM
lenzhotrod's Avatar
lenzhotrod
Yes 73 is ok. Your injectors see even less than that, being further down in the system. Also how accurate is the guage?
Old Jan 30, 2011 | 12:35 AM
Mr. Sandman's Avatar
Mr. Sandman
What's the International part # and did you get it from a dealer or online?
Old Jan 30, 2011 | 04:08 AM
bismic's Avatar
bismic
1843065C98 .
Old Jan 30, 2011 | 08:46 AM
Zookie400's Avatar
Zookie400
ok im still learning 6.0 stuff....where does this blue spring go and what is it fixing?
Old Jan 30, 2011 | 09:10 AM
cheezit's Avatar
cheezit
its the fuel pressure regulator spring. updated part adds fuel pressure.
Old Jan 30, 2011 | 10:39 AM
036.0stroke's Avatar
036.0stroke
i am thinking about getting the blue spring too. do you feel any power difference with it or just a little extra insurance against frying your injectors?
Old Jan 30, 2011 | 10:49 AM
npccpartsman's Avatar
npccpartsman
You would only feel a power difference if your fuel pressure is already low. It's insurance against injector failure, not a performance mod.
