need help identifying front axle
Old Jan 28, 2011 | 03:06 AM
fordfunadic's Avatar
fordfunadic
I have a 73 F250 highboy with a front axle that appears to be a Dana 10 bolt pattern, closed knuckle with drum brakes. however the typical identifying marks are not matching up with the "de-coders" the long side of the axle tube has NO markings or date codes. there are no tags/data plates on the cover and there is no 60 or 44 stamped in the corners of the pumpkin just a single code in the left lower corner 446CF. the truck was used when I got it and I belive the front diff has been replaced, and there are different gear ratios between F/R. If anyone can help I would greatly appreciate it.
Old Jan 28, 2011 | 04:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Dana 44-6CF front driving axles were used in 1959/74 F100's & F250's. Different versions were offered: with/without free running hubs, 3M or 3.5M lb. front axle capacity.
I could find no reference for 44-6CF's after 1974...in the 1973/79 Ford truck parts catalog.
1959/74 F250: There was also several versions of the 44-6CF-HD. No parts catalog reference after 1974.
Old Jan 28, 2011 | 02:13 PM
fordfunadic
Thank you for the info. It was my suspicion that it was a Dana 44 but I wasn't sure. Any idea if there is a disc brake conversion out there for this axle?
jy1956f100
May 9, 2008 04:53 PM
5356f100
Flathead V8 & Flathead 6
Apr 13, 2004 02:35 AM
manlikesford
Jan 11, 2004 11:29 AM
G_SHARPE
Nov 1, 2002 07:10 PM
fordmanSLO
Aug 12, 2001 12:53 AM
