Sponsored by: Real Truck
code reader problem
Old Jan 27, 2011 | 10:20 PM
Rice Equipment's Avatar
Rice Equipment
code reader problem
I tried to read the codes on an '02 SD but the reader won't interface with the truck. I tried the reader on an '01, and it worked fine. The '02 is a no start, and all fuses are good, as is the EEC relay.
Old Jan 28, 2011 | 11:12 AM
Rice Equipment
does anyone know where I might get info on a non responsive computer?
Old Jan 28, 2011 | 11:23 AM
cartmanea's Avatar
cartmanea
Sounds like you may need a new ECM. You could try getting a used one from a salvage yard or Ebay.
Old Jan 28, 2011 | 01:36 PM
dchamberlain's Avatar
dchamberlain
Before you go that far, make sure the ODB-II port has power. The OBD-II port shares power with the cigarette lighter (not the power point). See if the cigarette lighter works. If it doesn't, the fuse is probably blown.
Old Jan 29, 2011 | 10:37 AM
Rice Equipment
Thanks, I'll try the OBD port power next. sounds logical.
Bob
crzycrazycarl
Nov 4, 2010 04:53 PM
bkuuz1
Jan 11, 2010 12:02 AM
geraldo14
Jun 11, 2007 10:33 AM
KCMAGERS
May 8, 2007 12:36 AM
BodegaErik
Jul 2, 2006 02:41 AM
