Clearing trouble codes
Old Jan 27, 2011 | 09:02 AM
r stene's Avatar
r stene
Thanks for everyones help,One more ?, When clearing codes by unhooking the battery,will it shut off the light and clear codes or do I clear it with my scanner.
Old Jan 27, 2011 | 11:10 AM
pawpaw's Avatar
pawpaw
Either one will clear the code, but removing the battery B- cable also clears the KAM (Keep Alive Memory).
So, the computer will have to relearn some new things, like it's cold & warm idle strategy & it'll have to begin to build new fuel trim tables, as they are wiped with a battery cable disconnect.
It'll also have to be driven through a certain routene for the IM monitors to reset, so it'll be ready for emissions testing.
If you don't need to have emissions testing done right way, then the IM monitors will reset over time, after enough driving is done.
If you use your scan tool to erase the code, it won't mess with the KAM, so all of the above is avoided.
NICKSAN
Electrical Systems/Wiring
Apr 10, 2017 07:56 PM
97' DieHardExploder
Oct 31, 2014 04:20 PM
97' DieHardExploder
Oct 30, 2014 07:27 PM
weberr7
Jul 2, 2012 03:22 AM
Jules3084
Jun 13, 2011 11:32 AM
