Heater Core Failures
Old Jan 26, 2011 | 09:58 PM
TexasGuy001's Avatar
TexasGuy001
My friend has a 95 F150 with a 4.9 and is not able to keep a funtioning heater core in his truck for more than a few months. It doesn't matter if its one from the dealer or from the auto parts store. This has been an issue for the last year or two. Does anyone know what is going on with his truck?
Old Jan 26, 2011 | 10:03 PM
CJM8515's Avatar
CJM8515
Probably getting clogged by junk in the system. Whens the last time the truck was flushed and if the rads old it might be leaking out that junk.
Old Jan 26, 2011 | 10:04 PM
fdude64's Avatar
fdude64
if it keeps leaking might have a too high pressure cap
Old Jan 28, 2011 | 06:17 AM
TexasGuy001
That could be, but I'm pretty sure there is not any crud in the cooling system. He takes care of his truck and does the maintanace on it.
Good point on the radiator cap. I'll ask him which one he has on it.
Old Jan 28, 2011 | 10:48 AM
thechief66's Avatar
thechief66
Maybe this?
http://www.carquest.com/common/downl...ectrolysis.pdf
Old Jan 28, 2011 | 05:16 PM
Bob Gervais's Avatar
Bob Gervais
Originally Posted by thechief66
I had this issue with a 97 Taurus I had. Added a ground wire, and it solved the problem.
Old Jan 29, 2011 | 03:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I used to blow up heatercores all the time. (like 16 of them)
Went down to a 8psi cap, still happened.
I know the owner of an auto radiator shop and would watch him pressure test them to 30psi.
Electrolysis wasn't the issue.
I had also pressure tested the whole system.
Turns out I had a cracked head that wouldn't show up until I had to quickly back out of high rev's.
It was odd, but I finally figured it out.
Old Jan 30, 2011 | 11:21 PM
TexasGuy001
I'll ask him to check this out.
Old Jan 30, 2011 | 11:22 PM
TexasGuy001
Where did you add the ground strap?
Old Jan 30, 2011 | 11:23 PM
TexasGuy001
That sounds like a weird issue. I wouldn't think that it would cause heater core blow outs.
Old Jan 30, 2011 | 11:46 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I didn't think it could happen either. After all it IS a closed loop system.
But some of my heater cores were so expanded I actually had to pry them out of the heater box.
There was no corrosion or other signs of them having weeped.
The radiator cap never came open, not even with an 8 lb. cap.
I soldered a spade terminal to the header tank and plugged a ground wire to it.
I tried a flow restriction ahead of it.
I got on a first name basis with the owner of the radiator shop, and he must have lost his pants providing me warranty replacements.
Fixed cracked head, problem went away...
Old Jan 31, 2011 | 12:10 AM
TexasGuy001
Man that sounds like a real pain in the rear.
I'll tell him to try grounding it.
Old Jan 31, 2011 | 05:54 AM
Bob Gervais
It was a half-assed repair, because I didn't really care about the car, but I soldered a wire onto one of the hose fittings before I put the hoses on, and fastened the other end to the factory firewall ground.
vanceboroguy
Nov 24, 2014 09:09 AM
dohc_chump
27
Sep 28, 2010 03:04 PM
Ervie
Sep 30, 2007 02:09 PM
Mudman
Mar 25, 2007 05:08 AM
FordCrazy1970
13
Sep 5, 2005 11:41 AM
