catalytic converter
Old Jan 26, 2011 | 09:38 PM
Josue's Avatar
Josue
catalytic converter
I have a 95 explorer,
what is the symptoms for a clog catalytic converter??
some times I have a poor acceleration over 50ml/hr a mechanic recomend to change or eliminate the converter,
what happen if i eliminate this converter, beside the polution?
best regards
Old Jan 26, 2011 | 10:02 PM
85e150's Avatar
85e150
What is the basis for the mechanic making this recommendation? Did he test the exaust pressure upstream from the cat? Do all the other obvious diagnostics?
If you have no sensors after the cat, you can remove it without consequence to the running of the vehicle. There are fines etc, and if you have to pass a smog inspection, you need a new one.
Old Jan 27, 2011 | 06:50 AM
shorod's Avatar
shorod
When you try to accelerate over 50 mph does it buck and chug, or it just doesn't feel like it has power? As the above poster mentions, at a minimum the routine maintenance items should be checked (spark plugs, plug wires, air filter, fuel filter). The fuel rail fuel pressure should also be checked. If there is roughness at idle or under acceleration, in addition to the tune up items, the engine should be checked for vacuum leaks. Before condemning the catalytic converter I'd suggest you remove the "sensor 1" oxygen sensor(s) and see if that little hole before the converter makes a difference. If not, the converter is probably not the issue.
Some Fords started to transition to the OBD-2 diagnostic system in 1995. If your Explorer was one of them, it will have the "sensor 2" oxygen sensor mentioned in the above post and removing the converter would cause a diagnostic code and Check Engine Light (CEL).
-Rod
Old Jan 27, 2011 | 10:10 AM
KhanTyranitar's Avatar
KhanTyranitar
A plugged fuel filter causing a loss of power is far more likely. A catalytic converter is unlikely to clog unless a tuning problem is already present, such as rich condition, misfire, extreme lean condition, excessive oil consumption, low compression, or blown head gasket. The exception is if the converter has sustained physical damage due to a direct impact.
Old Jan 27, 2011 | 08:58 PM
Josue's Avatar
Josue
catalytic
i already did a tun up, only missing to clean the injectors,
the mechanic not make any test,
when i have this failure , the truck loss power, so the speed decrease, if i try to accelerate the engine not respond, so i loose the pedal do let the engine to reduce the speed then i increase the speed again, this append some times with a "explosion" sound,
and a few times the truck turn off by its self, but start again quickly and run normally
Old Jan 27, 2011 | 10:18 PM
shorod's Avatar
shorod
Has your fuel economy dropped recently? Maybe the explosion sound you hear is a backfire due to a really rich condition in the exhaust.
-Rod
kgallagher
2004 - 2008 F150
17
Jan 30, 2010 09:16 AM
RhinoScores
1983 - 2012 Ranger & B-Series
Aug 26, 2006 03:14 PM
scottddove
Mar 15, 2006 11:44 AM
boogity24
General Automotive Discussion
Jun 19, 2004 06:45 PM
Dapidude
Oct 23, 2003 02:08 PM
