1964 260 ?
Old Jan 25, 2011 | 04:33 PM
350crew4x4's Avatar
350crew4x4
1964 260 ?
I've got this motor that I'm going to be using but I'm not sure what size it really is So hopefully some one here can help me out. Hers what the numbers are on the block.
C40E-6015E
Thanks
Old Jan 25, 2011 | 08:22 PM
Beanscoot's Avatar
Beanscoot
Hmmm I checked a 260 I have and it's C4OE-6015-B.
But there could be more than one casting number.
Old Jan 25, 2011 | 11:15 PM
350crew4x4's Avatar
350crew4x4
Does anyone know what the second set of #'s stand for and I also found these #'s listed under 64" 289?
Old Jan 25, 2011 | 11:57 PM
85e150's Avatar
85e150
You look here, at the top of this forum?
Kelly hotrod - Ford Engines Page 2
Any numbers on the heads, same site as above:
Kelly hotrod - Ford Engines Page 3
You going to use this for a vintage car? You know about the 5 bolt bell housing pattern, right?
Old Jan 26, 2011 | 09:00 AM
350crew4x4's Avatar
350crew4x4
85e15six4mtod;
thanks I have looked there but I'm not sure what the second set of numbers mean ? It looks like the only way to be sure is to pull a head off and check the bore.
I do know about the 5-bolt housing I was lucky enough to get two good trannys with it and located a bell housing yesterday.
I am planning on putting this in a 1927 T roadster pick-up but would like to be able to run a 5-speed behind it.
So for now I am gathering info if anyone knows a tranny combo that will work let me know.
Thanks
Old Jan 26, 2011 | 01:24 PM
Beanscoot's Avatar
Beanscoot
Please post the second set of numbers. They probably are a casting date code.
With a five bolt bellhousing you will have difficulty with a five speed transmission. A toploader, toploader overdrive or three speed electric overdrive will fit up but an adaptor will probably need to be made to suit the five bolt bellhousing to a five speed.
What transmissions do you have now?
Old Jan 26, 2011 | 01:43 PM
350crew4x4's Avatar
350crew4x4
I'm not sure what they are I think they are both c-4 5-bolt but always looking for advise I would post some pics but can't seem to figure that out
Old Jan 26, 2011 | 01:54 PM
350crew4x4's Avatar
350crew4x4
Here are the rest of the numbers from the block
C40E - 6015E
4F10
thanks in advance
Old Jan 26, 2011 | 05:53 PM
Beanscoot's Avatar
Beanscoot
4 F 10 indicates the cylinder block was cast in 1964-June-10th.
I'll try to find my Ford Small Block V8 bible tonight to research that block casting number.
Old Jan 26, 2011 | 06:18 PM
Redhorse719's Avatar
Redhorse719
Casting #
Here is a break down on what the numbers/letters mean.
Breaking down the Ford casting number
Table 1.3
C9AE-9510-M
Decade alpha
B = 50's C = 60's D = 70's E = 80's
C9AE-9510-M
Year numeric
9 = 9th year of the decade
C9AE-9510-M
Model design alphanumeric
A = Full size ford (see table 2.1 for more)
C9AE-9510-M
Engineered component alpha
E = Engine (see table 2.2 for more)
C9AE-9510-M
Basic Part number, mostly numeric between 4 and 6 digits,
9510 = carburetor (see table 2.3 for more)
C9AE-9510-M
Engineering version alphanumeric (up to 3 digits but mostly single alpha digit)
M = 13th version of C9AF-9510 carburetor
Also check with the classic Mustang suppliers, they have an adapter to adapt a T5 to your bellhousing.
Old Jan 26, 2011 | 10:50 PM
85e150's Avatar
85e150
I don't see a 5 bolt bell here, but they have an adaptor to use the original bell with the T5. Le$$ expen$ive than the bell.
Modern Driveline - Classic Mustang Small Block T5 conversion parts kit 1965-1973
Old Jan 27, 2011 | 12:37 AM
Beanscoot's Avatar
Beanscoot
Here's the block casting number rundown. The C4OE-6015-E marked cylinder block superseded the C4OE-6015-B late in 1964. The "E" block was also the service replacement block after its introduction.
Both are 260 blocks with 3.80" bore.
Old Jan 27, 2011 | 03:12 PM
Redhorse719
You should only get the adapter since you will have to fab up a Xmission crossmember. Laurel Mountain Mustang list it as part # TRA-645-423 Adapter Plate. At CJ Pony Parts the Part Number: T5AP1. Hope this helps.
Old Jan 27, 2011 | 03:23 PM
Redhorse719
I went back and reread this thread and am not sure if you have a standard 5 bolt bellhousing or not. If you don't have one you might look on ebay, I see them there occasionally. I might have one if I ever decide which direction I want to go with my 63 Comet (260/4speed). Am thinking about a 5.0 FI/5speed.
samickguy15
Apr 9, 2015 01:32 AM
nwertz555
Aug 19, 2014 07:10 PM
Yuk
Oct 20, 2012 12:36 PM
93FordCTD
Apr 19, 2010 05:44 PM
4xfordman
1978 - 1996 Big Bronco
28
Aug 17, 2007 10:47 AM
