1978 - 1996 Big Bronco
Camber question
Old Jan 25, 2011 | 03:48 PM
ccbrett's Avatar
ccbrett
Camber question
Hey guys I have a 87 bronco with a 4 in lift my front tires lean in its not ball joints it could need adjustable camber bushings but i was looking at my lift drop brackets that lower the front axel assembly it looks like the drop bracket is also the same one for the six inch kit now if the axel was mounted in the hole for the 6 in kit and has a 4 in lift spring in it then that could cause the problem what do you guys think.
Old Jan 25, 2011 | 03:51 PM
Truck Paradise's Avatar
Truck Paradise
The lower brackets are for the 6" lift. If you have negative camber, (top of tire in) and you used the lower holes then that's probably your problem. The adjustable bushings are for fine tuning the alignment.
Old Jan 25, 2011 | 04:06 PM
ccbrett's Avatar
ccbrett
That what i was thinking i bought this thing like this and just got to looking at it Thanks for the help.
Old Jan 28, 2011 | 02:01 AM
ccbrett's Avatar
ccbrett
That fixed the problem. rides so much better
Old Jan 28, 2011 | 09:01 AM
Truck Paradise
Awesome! Glad you fixed it.
Wbrann51
Oct 21, 2019 09:47 AM
87thhunter
Oct 6, 2016 05:24 AM
Micheal G
Jun 18, 2016 07:33 AM
jtapal
20
Jan 7, 2016 10:24 PM
rhetor
May 13, 2004 07:45 PM
