1995 4x4
Old Jan 25, 2011 | 02:44 PM
jeepers's Avatar
jeepers
1995 4x4
Maybe i`m dumb,what is causing the front end to make a binding feel when backing up and wheel is turned? usually right front.....normal for 4x4 or is it the tire size or axle bindup?.....tires are 31x10.50x15 on alum.rims. and front end is squatting (weak springs)?
Old Jan 25, 2011 | 02:51 PM
jas88's Avatar
jas88
It's gonna do that if you turn the wheels hard and have the front hubs engaged.
Old Jan 25, 2011 | 02:53 PM
CWPottenger's Avatar
CWPottenger
Check the front U-joints, also might be rubbing so pull wheels and look to see if anything shows signs of contact.
Old Jan 25, 2011 | 03:10 PM
jas88's Avatar
jas88
It might just be rubbing, with TIB/TTB when you go in reverse the front squats and will point out any clearance problems. Check your radius arms, that's where they usually rub first. You will have a shiny vertical stripe where the tire is rubbing.
Old Jan 25, 2011 | 03:44 PM
jeepers's Avatar
jeepers
Unhappy 95 4x4
usually does it with or without hubs engaged,(auto hub).....U joints were replaced not positive about inner ones?.....hey i`m losing it!
Old Jan 25, 2011 | 03:47 PM
jas88's Avatar
jas88
RU sure your auto hubs are unlocking on both sides?
jeepers's Avatar
jeepers
also it usually does it in reverse with wheel turned left.....It`s probably a clearance issue,but thanks for the feeback!
Old Jan 25, 2011 | 03:51 PM
jeepers's Avatar
jeepers
HMMMM not sure about those auto hubs.....Rather have manual lock ones,always had better luck with those.....But to convert them $$$$$$$$.......I`ll have to check that out.
bobsplus
6.7L Power Stroke Diesel
Apr 14, 2012 09:14 AM
iron1951
Mar 15, 2010 09:40 PM
302F250
Mar 25, 2008 10:00 AM
kdbbmanton
Modular V8 (4.6L, 5.4L)
Jul 31, 2005 02:09 PM
osull
Oct 10, 2003 11:10 PM
