Yes, it is regular unleaded gasoline.
Other than lubrication, what is your concern?
I will guess you also would not run your truck on a high percentage of vegetable oil (vo) which i do and have been since 2003. I have been adding RUG for years.
I typically run 100% vo from March to August.
To me there doesn't need to be any other concern other than lubrication. The fuel is what lubricates the primary pump on the frame rail. But since you haven't had any problems for years, do what works for you.
I guess I wasn't aware that VO didn't have lubrication. I have considered using it but haven't taken the time to get involved with it. Certainly one way to cheapen the operation of your truck.
VO is excellent for lubrication, actually a mix as low as 2% beat out all the additives tested in this study. The big downside though - for us living up north it has a much higher cloud & Cold Filter Plug Point than #2 diesel, we'de gell in a heartbeat during winter. Last year Minnesota suspended their 5% bio requirementin #2 diesel because the temps dropped so low some truckers were gelling up. Sorry to hijack Jim!
Other than lubrication, what is your concern?.......
David, it was my understanding that with ULSD (since 2007) gasoline is not as effective at lowering the CFPP as #1/Kero, it lowers the fuel viscosity, cetane number, and flash-point and can be a nasty fire hazard if the mixture ratio is too high. But not sure what the effects are when you mix VO, diesel and gasoline all together. You probobly don't see #1 diesel/kerosene at the pumps in South Carolina.
...You probobly don't see #1 diesel/kerosene at the pumps in South Carolina...
Sorry again Jim!
I have used K1 and like it. RUG is just lower priced and gives me a similar result.
I have used a variety of chemicals in varing percentages over the years.
My safety test of flamability. I pour my fuel in a jar, light a match and stick the burning match into the fuel.
The fuel consistantly extinguishes the burning match like 100% diesel will.
No need to apologize about the hijack Rich and Mark, This had turned into a very interesting topic. This is one of the things that I love about this forum.
Originally Posted by dn29626
What made you thing vo had no lubrication?
In the first post you linked my concern about lack of lubrication when running gasoline to a similar condition when running VO. I thought that there was something about a lack of lubrication from VO that I didn't know about. I have used biodiesel for quite a few years, when it is available, and will run it again.
I'm the same way Mark. I will use biodiesel during the warmer months when the stations up here sell it. There is a biofuel plant only about 1/2 an hour away and I like supporting the local farmers when I can - by buying soydiesel and ethanol. I just make sure to run an additive since bio tends to attract moisture.
Rich,thanks for supporting America's farmers! Around here, if biodiesel is more than 2 cents higher than regular diesel it won't sell. It's felt that there isn't enough benefit over that. What additive do you run to prevent moisture accumulation?
If I'm driving through Minnesota and fill up they have a mandatory 5% (B5) bio requirement. In South Dakota there are a few stations around town that offer a B10 and one were we go camping that has B20. Usually see it offered from Jun-Sep time frame. I'm not sure how states differ but the price is about the same as #2 here - or else nobody would buy it around here. Must be some tax incentive or something in place.
Mark,
I always run Dieseltreat Summer or Winter blend - it has a water dispersent in the formula. Water contamination is more of a concern during long term storage or in equipment that sits for long periods at a time. When I'm burning tanks at a time pullin the camper during the summer it doesn't have time to sit long.
