Engine quit on highway
Old Jan 23, 2011 | 08:06 PM
banjodriver's Avatar
banjodriver
Traveling @ 60mph, engine @ operating temp, 40* ambient temp. The engine stopped running. Pulled over to the side and while I was slowing down in gear (drive {automatic} ) the engine restarted on it's own. Traveled additional 4 miles took the next exit and it stopped again. This time I started it on the first try climbed a short 12% grade but the engine struggeled. Not missing, but ran slightly, very slightly rough. Any thoughts?
Old Jan 23, 2011 | 08:10 PM
Fully_Loaded's Avatar
Fully_Loaded
CPS if I had to guess
Old Jan 23, 2011 | 08:11 PM
Fully_Loaded
Also need more info, what kind of vehicle is it how many miles and so forth
Old Jan 23, 2011 | 08:59 PM
4inchlovin's Avatar
4inchlovin
sounds like another CPS victim
Old Jan 23, 2011 | 09:10 PM
woodnthings's Avatar
woodnthings
Can you check the PCM for stored codes? You will need more than a basic OBD II code reader to do it.
Did you get the CPS recall done?
What is the oil level on the dipstick? If the oil level is low, you may be starving the HPOP reservoir of oil and it is dying. Then as the oil gets back down it will start up.
If that is good I would start looking for wire bundles on the engine that may be intermittently shorting out. Wiggling them while the truck is running is a pretty good way to find them. Pay special attention to the fuel bowl heater area and the wires around the drivers side valve cover.
Old Jan 23, 2011 | 11:27 PM
USAF CCM's Avatar
USAF CCM
I agree with above.....get codes checked, but I suspect CPS.
Old Jan 24, 2011 | 08:39 AM
Brother Les's Avatar
Brother Les
Was the area that you were driving, 'wet'/raining/snowing and did you drive through any water to splash into the engine area? I believe that you may have gotten some moisture pasted the CPS o-ring seal and caused a 'shutdown'. Take the CPS out and put vasoline or a little electrice grease on the seal to make it water tight.
46yblock
May 2, 2009 10:45 PM
Mr. Obvious
Modular V10 (6.8l)
Jul 30, 2008 09:31 PM
farmnaggie
Jun 3, 2006 10:32 PM
kmbarr100
Jan 12, 2005 06:44 AM
johngerardi
1983 - 2012 Ranger & B-Series
Feb 15, 2004 12:18 AM
