Is this sound normal?
Old Jan 23, 2011 | 02:59 PM
fnmoving's Avatar
fnmoving
First I want to say thanks to you all. You have helped many times! Ok, so when I am sitting at a stop or under a light load, I hear this wierd clunk. Sounds like a door shutting. I can actually feel it in the floorboard. Happens about every 45 seconds or so. I drive a 2005 f-350 PS LB SRW. Does anyone know what this might be? Thanks again in advance.
Old Jan 23, 2011 | 04:17 PM
lenzhotrod's Avatar
lenzhotrod
Sounds like a bad or leaking vacuum system. The sound you are hearing sounds like the vent door.
Old Jan 23, 2011 | 05:41 PM
foul1's Avatar
foul1
Same here like a non metalic thunk. My hubs arent working so Im sure thats what mine is. Normally mine does it in defrost setting.
Old Jan 25, 2011 | 09:43 PM
fnmoving's Avatar
fnmoving
So is there a way to test the vacume system? My hubs are not working either.
Old Jan 25, 2011 | 10:00 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
I would suspect that you have a vacuum leak and what you are hearing is the "blend door"...although the regular cycling of the noise is puzzling. In some modes of climate control operation (defrost) the a/c compressor will cycle on and off. I wonder if this is what you are hearing.
Old Jan 25, 2011 | 10:22 PM
fnmoving's Avatar
fnmoving
It definetly sounds like a door shuting. Can I test the vacume or leaks?
Old Jan 26, 2011 | 09:17 AM
1bad04's Avatar
1bad04
Wow, My 04 4x4 does the same thing! I would love to know what the hell it is....Its a clunk sound right?
Old Jan 26, 2011 | 09:47 AM
clane's Avatar
clane
My 05 was doing the same thing. Door shutting and hubs not working. I replaced the 4x4 vacuum solenoid and all is good. Hubs work and door quit making noise. Part number is 7C3Z-9H465-A. Hope this helps.
Old Jan 26, 2011 | 09:50 AM
1bad04's Avatar
1bad04
Could you please elaborate on what you mean about your (door quit making noise?)
Old Jan 26, 2011 | 09:55 AM
clane's Avatar
clane
ac vent mix heat door
Old Jan 26, 2011 | 12:19 PM
dchamberlain's Avatar
dchamberlain
The best way to diagnose vacuum problems is with a hand pump/gauge combo.
Start at the electric vacuum pump on the passenger side firewall in the engine compartment. Hook the gauge up to just it and turn on the key. The pump should draw a vacuum and then shut off and then hold the vacuum. Then follow the line down and hook the gauge up there. Again the pump should draw a vacuum, shut off and hold it.
Just keep going down the lines one section at a time. As soon as you hit a spot where either the pump doesn't draw a vacuum and shut off, or the vacuum bleeds, then you've found the leaking line.
The hand pump can be used to test for leak downs. For example, you can hook the hand pump to a vacuum hub nipple, hand pump down about 15 PSI and see if it holds. If it doesn't hold, it's leaking and needs to be repaired, etc.
fordrules_2013
Oct 13, 2013 06:33 PM
Robert6401
Nov 25, 2012 06:52 PM
Pud12343
15
Aug 21, 2007 09:36 PM
DRanchero
Jun 30, 2003 12:19 PM
Black88GT
Jun 22, 2003 02:27 PM
