Need help choosing engine for towing...
Old Jan 24, 2011 | 12:27 AM
Dads79's Avatar
Dads79
7.3 Powerstroke !
Old Jan 24, 2011 | 12:38 AM
jmachen1's Avatar
jmachen1
ford i6 300 tweeked a little will be exaclty what youn need
Old Jan 24, 2011 | 12:42 AM
Kalve's Avatar
Kalve
Are you going to make any changes to the truck besides engine,trans & gears? An what engine & trans is in it now & why change the engine an trans that is in it?
Old Jan 31, 2011 | 02:38 AM
Rory428's Avatar
Rory428
What are you planning on towing, & how far, and any big hills? I agree with most others, if you are going to tow much, I would look at either a FE or a 460, and I would never tow much with a AOD neither. The AOD`s suck power, are not that great for reliability, and if you were to use a small block, chances are the only time you could use the overdrive while towing is downhill, or if lucky, on a dead flat road. If hyou only plan to tow a tent trailer, dirt bike trailer,small aluminum boat, or small utility trailer, sure the SB/AOD would likely be fine, but if you were planning on towing something heavy, like a car, you really should have at least a F250.
TNT1968
Nov 25, 2009 09:15 AM
joegeoghegan317
Nov 20, 2009 04:47 PM
elemint
Oct 4, 2004 09:01 AM
ACESN8S
Dec 25, 2003 11:39 AM
CACWBY
Jul 15, 2003 05:20 AM
