Sponsored by: Real Truck
Need help with an odd electrical problem
Old Jan 23, 2011 | 01:48 PM
apoc192's Avatar
apoc192
Hey everyone. My 2005 f250 PSD has developed an odd electrical issue. Here are the symptoms:
Power mirrors inoperative
Power windows inoperative
Power locks inoperative when key is in and ignition is turned on, otherwise they work fine.
I've pulled all the fuses on the drivers side but they all look ok. Any ideas?
Old Jan 23, 2011 | 04:59 PM
Surge08's Avatar
Surge08
I would say you need an electrical diagram and follow it til you find the culprit.
Old Jan 24, 2011 | 09:22 AM
apoc192's Avatar
apoc192
Any other ideas? I don't even know where to start with an electrical diagram.
Old Jan 24, 2011 | 09:41 AM
BenFranklin's Avatar
BenFranklin
Do you have keyless entry?
Old Jan 24, 2011 | 09:43 AM
apoc192's Avatar
apoc192
Yes I have keyless entry. The keypad works
Old Jan 24, 2011 | 10:30 AM
BenFranklin
Do you have a meter or test light to put on the fuses? Everything I am finding is not adding up for the symptoms you have unless you have a few blown fuses.
Old Jan 25, 2011 | 05:00 AM
apoc192's Avatar
apoc192
I will recheck the fuses. Also I have a symptom I didn't mention before. The cabin dome light will not activate when the doors are open, but will work manually by setting the dash board brightness to max.
Old Jan 25, 2011 | 06:42 AM
BenFranklin
Jeeze....let me check some more, this is sounding like a grounding issue. A weird one at that...
Old Jan 25, 2011 | 08:39 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'm wondering if it isn't a door switch issue.
Old Jan 25, 2011 | 08:47 AM
BenFranklin
Well, PM me your email and I will email you PDFs of everything and show you what i am seeing.
Old Jan 29, 2011 | 03:10 PM
apoc192's Avatar
apoc192
Well it appears to be a door switch issue. I could hear a humming coming from the switch when it was engaged, which was a huge give-away. Took off the switch and removed the housing. It has some white stuff reminiscent or mold (but not actually mold, more like oxidation from a short) around the solder where the wiring harness feeds into the prongs. I am hoping this is the culprit.
Now it is time to buy the part from Ed. I think this is the right part
www.partsguyed.com
part 7, Regular, super cab Left - Power window - Power window - for 75 dollars. If someone could confirm this for me I can go ahead and buy the part.
Btw, according to Ed's site, he is having some kind of medical emergency. Best wishes to him and I hope he recovers quickly.
Old Jan 29, 2011 | 06:55 PM
apoc192's Avatar
apoc192
bump so i can buy the part
The Grinch
Aug 29, 2014 10:10 AM
ron2681
2004 - 2008 F150
Jan 12, 2012 04:09 AM
mudsculpter
General Automotive Discussion
Aug 24, 2005 03:37 PM
wiskyseria
Nov 8, 2004 11:01 AM
Hsi95
May 29, 2004 09:15 PM
