Sponsored by: Real Truck
Back-up sensor problem
Old Jan 21, 2011 | 08:39 AM
spud57's Avatar
spud57
My back-up sensor is coming on all the time when I go into reverse. It does shut off when I press the OFF button.
Not sure where to start trouble shooting but thought best to get any feedback from anyone that has experienced it and the fix. I guess it is either a bad module or a sensor.
Thanks
Scott
Old Jan 21, 2011 | 09:01 AM
acf6's Avatar
acf6
This happens to me all the time, I just turn it off while I'm backing up and it has always fixed itself after I turn my truck off and leave it for a little while
Old Jan 21, 2011 | 09:02 AM
scottzj's Avatar
scottzj
Hangin 10 bra
Clean it really good, as mine did the same thing. It didnt look like they were dirty but they were, also check the angle its pointing at, cuz if something hit it, then it could be pointing at the ground. Then if its still doing it, unplug each sensor, one at a time and find the one causing the problem. Either replace it or leave it unplugged.
Old Jan 21, 2011 | 09:08 AM
spud57's Avatar
spud57
Thanks guys. I gave them a wipe but perhaps some soap and water would be better. If that doesn't help I'll try unplugging one at a time.
I do find them usefull so I do have to get them fixed.
Old Jan 21, 2011 | 10:09 AM
pbeering's Avatar
pbeering
Clean the outsides, check for correct alignment, then unplug each one and check for corrosion. Clean as needed and add either dielectric grease or Fluid Film to the connection.
380tom
Feb 26, 2013 10:04 PM
jayc3169
Jan 8, 2013 11:19 AM
ssimpson6
Jul 4, 2010 10:42 AM
MikeDesire
Feb 15, 2006 08:05 PM
tkj99
Jun 12, 2003 08:20 PM
