2004 tranny
Old Jan 20, 2011 | 08:11 PM
finlander's Avatar
finlander
2004 tranny
What would cause the tranny to slip out of gear at around 32 mph? It acts like I had dropped it into neutral. Started doing this on Monday. Thanks for any help.
Old Jan 21, 2011 | 08:02 PM
finlander's Avatar
finlander
04 F150 tranny
It doesnt do it when the truck has the o.d. off. What switch should I look for? Anyone???
Old Jan 21, 2011 | 08:38 PM
hunt3r's Avatar
hunt3r
I'm not a tranny expert but did you check the fluid level?
Old Jan 21, 2011 | 09:20 PM
FordLvr30's Avatar
FordLvr30
Is it at 32mph or 42mph that it is slipping? 32mph spounds like no direct drive (No 3rd gear/Broken direct drum). Slipping in anything over 42mph would indicate an overdrive band issue. If you say it doesnt do it with the od off. It is likely the later of the two...If the direct drive is broken you will not have third or fourth gear. Only 1st/Reverse(Use same planetary) and intermediate(2nd Gear) will work...
Old Jan 21, 2011 | 10:16 PM
finlander's Avatar
finlander
2004 F150 tranny
Yes, right around 32 mph, and the rpms go up like I was revving the engine in neutral. This drive drum you speak of, where is it at? It seems to get into 2nd gear before it hapens. If it were the bands, of fellow told me that this tranny's bands cannot be adjusted. Thanks.
Old Jan 21, 2011 | 10:21 PM
finlander's Avatar
finlander
04 F150 tranny
Another thing I forgot to mention is there have been no displays popping up telling me something is amiss.
Old Jan 22, 2011 | 09:46 AM
jk080's Avatar
jk080
Transmission Rebuilder
If it don't slip out of gear with the overdrive off then it sounds like the problem is with overdrive, which is the band.
There are a few things that it could be, but the most common one is a small e clip on the servo that applys the band likes to break and get stuck in the valve body preventing the valve to move and causing the band not be applied.
During the 3-4 shift the overdrive band comes on and the forward drum is released, so if the band cant hold when the forward gets released and it quits pulling forward.
Read this post
https://www.ford-trucks.com/forums/9...ml#post9206889
mantta
Dec 18, 2002 09:48 PM
sparky
Nov 30, 2002 05:33 PM
youkonbob
Aug 30, 2002 03:40 PM
dzk007
Aerostar
Apr 13, 2002 11:13 AM
Jan 28, 2000 06:08 PM
