Intercooler Boots
Old Jan 20, 2011 | 11:39 AM
John - Wenatchee's Avatar
John - Wenatchee
Intercooler Boots
How hard is it to replace the intercooler boots on a 2002 F250? I was thinking of ordering the set from Riffraff.
Thanks
John
Old Jan 20, 2011 | 11:50 AM
robs01f250's Avatar
robs01f250
not hard at all. About 20-25 minutes and it will be done
Old Jan 20, 2011 | 11:52 AM
bfife's Avatar
bfife
still plays with trucks
easy-cheezy. remove old clamps and boots. clean tubes with Brake clean or something similar. Spray inside of boot and outside of tube with hairspray. install boots and tubes, tighten clamps. make sure and order the intake manifold inserts also
Barney
Ponyboychris's Avatar
Ponyboychris
Just the four boots for the pipes is a easy 30 minutes tops like Rob said. The two intake boots take a bit longer since you need to remove the spider.
Old Jan 20, 2011 | 11:55 AM
John - Wenatchee
Thanks, I didn't think it would be too hard. Forgive me, but what is the spider? Could you please point me in the direction of the intake manifold inserts?
Old Jan 20, 2011 | 12:01 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
If you do the intake don't forget the plenum inserts, money well spent
Riffraff Diesel: RDP Plenum Reinforcing Inserts™
PaysonPSD's Avatar
PaysonPSD
The boots on either end of the IC tubes are fairly easy. The ones from the intake plenums to bottom of spider require the spider be removed. If you change those I highly reccommend getting these RDP Plenum Reinforcing Inserts™ to prevent deforming the plenums and causing a boost leak.
When I R&R the boots I use a corless drill with a 1/4" socket adapter and long extensions to get to the hard to reach t-bolts, like under the spider and at the IC. Also suggest you get the deepest 7/16" socket you can find. A cotter pin removing tool will help get the plenum boots back on. Another tip for getting the plenum boots on is to attach one boot to the plenum and the other to the spider.
Edit: Damn I'm slow. I could've sworn ther were zero responses when I started typing.
Old Jan 20, 2011 | 12:13 PM
PaysonPSD's Avatar
PaysonPSD
That is the 4-way manifold attached to the front of the turbo.
Old Jan 20, 2011 | 12:31 PM
John - Wenatchee
Thanks for all of the great advice. So best I can figure is that I need the following to complete the job.
Riffraff Diesel: RDP Complete Aramid Boot Kit
Is there anything else I should?
Old Jan 20, 2011 | 12:46 PM
PaysonPSD's Avatar
PaysonPSD
There is an o-ring between the spider and turbo but if it is serviceable re-use it. It is available from Guzzle Dieselorings.com Not listed on his site, just give him a call. (Thanks Clay)
Edit : Removed wrong link.
Old Jan 20, 2011 | 12:50 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
When you have the IC tubes off, you can take the foil off the hot side pipe, if you didn't already. I guess you didn't if you are asking about taking them off.
Old Jan 20, 2011 | 01:08 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Originally Posted by PaysonPSD
There is an o-ring between the spider and turbo but if it is serviceable re-use it. It is available from Guzzle if not serviceable GTP38 Compressor Housing O-ring
Just for clarification that is the large one for the compressor housing to compressor back plate. Guzzle does have the correct ones but you will have to call him as they are not listed and are reusable.
Old Jan 20, 2011 | 01:31 PM
PaysonPSD's Avatar
PaysonPSD
Thanks for the correction Clay. Edited original post.
Old Jan 20, 2011 | 02:29 PM
John - Wenatchee
Is there some place where I can download the factory service manual?
shadows4
Feb 11, 2014 01:16 PM
crazymut
13
Mar 21, 2010 10:20 PM
F350JOHN
Jul 23, 2009 07:59 PM
kawajockie
Jun 29, 2008 01:02 PM
John Kiernan
Jun 14, 2007 08:02 PM
