ok. thanks. is there a (+) or (-) to the IPR? i dont want to burn it out. there is a international dealer about 2 blocks from here, ill just run over there and buy a pigtail, i just got one for a DT466 last week for about $10.
I believe there is and I have been looking for the schematic for you and can't find it. When I get home, I can look it up in the manuals I have. Sorry I can't help you right now.
Here is another possible help (but the video is long - start at about the 40 min. mark)
Ok guys, I got the Turbo off this thing and I am going to change the STC fitting. Is There anything else to check or look for while I am this deep into it? I wanna make sure its fixed and I didn't miss anything. Any suggestions?
New dummy plugs and depending on the year the engine was made, an upgraded turbo drain line.
Ford has new standpipes also, but I am not sure of how important it would be to change them out. Personally I would go ahead and change them, but I don't know enough about the actual failure rate to strongly recommend them.
I can't recall if you said - does he still have his EGR cooler?
