`06 Milan, Left Front Turn Signal Not Working
I have an `06 Milan with 108,000 miles on it so it's a tad out of warranty. I just noticed that the left front turn signal isn't working. The bulb is fine but it's not flashing when it's supposed to. The right side works fine and the left rear is fine. Also the left rear doesn't flash fast to indicate there's a bulb problem and the system check doesn't show a problem either. Any ideas?
Any chance you can track down a wiring diagram for the vehicle? The older cars and trucks are so simple - a single flasher is routed to either side by the turn signal switch. Most times the problem is a bad ground at the socket itself; the other times the turn signal switch is bad. With something that new, I don't even know if it uses a flasher or if it's computer controlled. Do the hazards on that side work? If so, you could eliminate the socket and focus on the turn signal switch. Without a wiring diagram, it's hard to know what else to troubleshoot.
Received 3,110 Likes
on
on
on
brksb46041
15
12-12-2006 04:38 PM
S4patrick
13
12-12-2005 04:53 PM
