seering stablizer
Old Jan 19, 2011 | 06:18 PM
BigCountry77's Avatar
BigCountry77
seering stablizer
im doing a steering conversion on a 75 highboy. im using a box off of a 78 f-150 4x4. im going to fab up a drag link but i was wondering what to do about a steering stablizer.
Old Jan 19, 2011 | 06:36 PM
mark a.'s Avatar
mark a.
I put one of those dual stabilizer kits from Trail Master on the last one I did.
Old Jan 20, 2011 | 09:08 PM
BigCountry77
what year do i need to order
Old Jan 20, 2011 | 10:13 PM
slstreit's Avatar
slstreit
Multiple steering stabilizers are for disguising steering problems. Fix the steering problems and THEN add one stabilizer for controlling the big tire force. If you are converting a high chasis power assist to 771/2 -79 integral power steering gear (and bless you if you go with a high pinion 60 in the conversion) then there are after market drop drag links available. Since you are fabbing your own drag link, get the geometry correct and it should drive real nice. Steering correctness is about correct angles of the steering components. I live in CA and I often wonder how these trucks here with the front end twice as high as the rear-where you can't see over the hood and the headlights don't find the road (CaliLift-Lame)-can even drive these things with the caster out that far. Do a correct job and stay away from multiple stabilizers. They just add force and wear to your steering gear/components. Do it right, once, the first time...
My $.02
Old Jan 21, 2011 | 11:47 AM
BigCountry77
what do i need to tell the ppl at the parts store when they ask what year i need
Old Jan 21, 2011 | 12:32 PM
704 dentside man's Avatar
704 dentside man
If you're looking for a single, it doesn't matter, it'll just be a couple u-bolts, nuts and backing plates...and put it where you deem necessary. If you're looking for a dual stabilizer vehicle specific kit, order it for the parts you're using...so the 78, but I really think it'll be a generic 'kit', nothing specific about it at all.
As mentioned above though...steering stabilizers are a band aid, fix the root problem.
luisp1966
Mar 5, 2012 09:07 PM
deveaum
Oct 26, 2009 08:15 PM
star
Apr 3, 2007 10:25 PM
Wieckster
Jan 13, 2007 04:01 PM
MarkF250
Oct 10, 2003 09:00 AM
