Wanting to replace shocks on my truck, was wondering what shocks provide the best ride and handling in the aftermarket category. have had Bilstien 5100 and thats like riding on a lumber wagon. and the factory ones are just a little too soft for me. so I'm looking for something in the middle. Any help would be appreciated
I recently put KYB struts on my '04 2wd and have had Skyjacker rear shocks for nearly 3 years. If you want more control I would recommend Bilstien HD struts and shocks. If you don't carry much of a load or tow much the KYB should work fine.
I had the same dilemma once. My solution was Rancho 9000 XL's. They are adjustable and a very high quality shock. I have been very satisfied since installing them a year and seven months ago. I have them adjusted so that the ride is firm and controlled, but not harsh. It could best be described as like a luxury european sedan.
They can be done either way. I don't change mine often so I didn't get the module. It is very simple to just reach down and turn a little a little **** on each shock. Takes maybe 30 seconds per shock, nine settings available.
I don't know what the recommended milage is, but stock shocks are usually pretty much done by 30-40 K miles. It seems most quality after market shocks are way better than stock shocks.
Rancho RS9000s are the way to go. This is the third truck I've put them on and I think they are the best value and the best ride. Being able to tune the dampening on the shock lets me get the ride just the way I like it. I run the Quick Lift up front, no need to spend the extra cash on a level kit, and it sits just right. Rancho had a program that ended Dec 31, if you bought a set of 4 RS9000s, they send you a free My Ride wireless tuner with compressor. $270 I wasn't going to spend, but it's nice to get something like that in the mail anyhow. Maybe they'll do that again.
Hi sorry for getting like this. I am new in this. I just both a Ford F-150 platinium 2016 and I am looking to change the shocks. I drive it 4 day a week in the street but on the weeken I always used it on a off road with lost of small bumped that make it jump a lot. I am thinking on the Fox 2.5 factory series front and rear. Any advice ? Thanks
Thanks you For the videos it helps a lot. I am still thinking if I should buy the fox 2.5 factory series or just the 2.0 performance for my f150 platinium 2016
