Disc Brake Conversion?
Old Jan 19, 2011 | 08:30 AM
74ford4x4's Avatar
74ford4x4
Ive got a 74 ford 100 4x4 with 4 wheel drum brakes. Where can i purchase all the stuff I need for a disc brake swap?
Old Jan 19, 2011 | 09:30 AM
akforceten's Avatar
akforceten
just find a newer 70's model with disc brakes an swap the axle out.
Old Jan 19, 2011 | 09:34 AM
HIO Silver's Avatar
HIO Silver
Try Early Bronco Enterprises. They've got stuff for the drummed D44.
Alternatively, go 'yarding and grab, from the knuckles outward the disc brake setup from a 76-79 1/2 ton (F100,F150, Bronco) with a disc-equipped D44. You'll also need a proportioning valve to adjust the brake bias. However, sometimes it comes out more economical to simply buy the entire D44 instead of swapping parts.
Old Jan 19, 2011 | 12:52 PM
Shane in WI's Avatar
Shane in WI
I have a 75 F100 2wd truck w/ the Brake cyl, booster, prop valve, w/ the correct pedal for $100 if that helps. It also has the spindles, calipers, and suspension. Don't know how much will work for a 4wd truck. Parts are in WI. shane@sandenwood.com
74ford4x4
Nov 8, 2011 11:13 PM
74ford4x4
Jul 25, 2011 06:17 PM
fordman60
Jan 5, 2010 11:38 AM
Ford Lifer
1997 - 2003 F150
Nov 11, 2004 10:54 AM
