Ford 460 carb choice
Hey guys,
I'm looking at getting a new carb for my 84 Ford 460. Presently its all stock, with a 4spd trans. Its 4x4 and in the next year or so, I plan to lift it 4 inches, get a 5spd trans, 35 inch tires, and perhaps get a new cam, heads, and intake. I'm not gonna be doing anything crazy with it occasional towing, hauling, mainly daily driving. I do want some get up and go and be able to have some speed so I am not getting run down on the free way, and break loose tires on occasion.
My 4180 Holley carb is stock and its shot, power valve blown I'm sure gaskets worn etc.
I've narrowed the choices down to one with a cfm of 600-750, vac secondaries, elec choke, and it needs to fit the pattern of the 4180.
I've figured either a Street Avenger, or 4160 Holley would be the best.
What do you think I should get?
I also want to get 10 or more mpgs empty as it will be a daily driver.
I would go with a 750 Edelbrock myself. It worked great on my 77 I had with a mild 460 in it. I used it with both all stock engine and after I installed a Performer intake, headers, a CompCams 268H cam, lifters and valve springs as well as an Edelbrock double roller timing chain.
The 670cfm Truck Avenger would be a good choice as well.
Holley Performance Products 670 CFM Four Barrel Carburetor 0-90670
Make sure you get a full 12 volts to the choke, don't use the original alternator STA terminal that Ford used (Ford had a lower voltage choke cap at 6-7 volts).
Pat
Holley 0-80457S - Holley Model 4160 Non-Adjustable Float Carburetors - Overview - SummitRacing.com
Couldn't be happier so much better! It was bolt on and fire right up.
Holley 0-80452 - Holley Model 4160 Adjustable Float Carburetors - Overview - SummitRacing.com
<http: www.summitracing.com="" parts="" hly-0-80452="">
California smog legal was a big deal in my case. Looks like the price has gone up, big surprise . . .
But, that one isn't listed as fitting your truck ('82 F100). Was it a factory 4 bbl?
Pat</http:>
Thanks!
Any advantage to the adjustable floats over the non? It says the non shouldn't ever need adjustment.. which is fine with me.
Well the engine isn't stock, it has has a performer rpm intake to fit 4bbls. The 4180 was just thrown on it to get it running and sold by the previous owner. They were running a custom built racing carb; but they got 6-8mpg. I'm guessing 750cfm, but theres no way i'm going that big.
For my '77 F-250 / 460 / C6, I ordered a 0-80452:
<HTTP: hly-0-80452="" parts="" www.summitracing.com="">
Pat</HTTP:>
Pat</HTTP:>
Rusty_S
06-22-2016 07:52 AM
brian eiland
43
03-03-2016 07:06 PM
quakerj
12-23-2014 07:42 PM
